  • Replies 180
Posted Images
Remember when we went nuts and changed nicknames to celebrities and such
Check this, haha
http://web.archive.org/web/20030517061743/...s=&threadid=292
Hahaha, I remember that - it took me so long to figure out who was was who!
Damm I had a hot wife!!! Minhs nick shouldn't be DR GTR.. should be
SDU4EVA! LOL
man thats OG. I still remember prank coming on for teh first time and posting how he is new and just got a skyline. I remember danny (Hustlr) and Jen Miss S13 Nissky and a few others. That was even before all the TWS peeps even showed up. damn thats early days badly.
That bathurst cruise was the craziest weather ever!
Pit straight and we are all posing in the sun, mountain straight and it starts sprinkling so I put my window up, top of the mountain and its bucketing down.. everybody hits the brakes, conrod and back to spitting, last corner and the sun is out again. Then we turn out of bathurst heading back to Sydney and get 5mins along the road and it's snowing, wtf!
i'm remember it was like snowing at one stage! i think it was when we were coming back
Wheres Donnie and Tony?? Last time i saw them was at One World and Utopia nearly 2 years ago. They got me off my nut and i didn't sleep and couldn't stop talking till morning.
Sounds pretty normal for you Loz !
'02 Crew Sign in Here if you're still alive!
You know who you are. URINE's thread was getting a little messy so let's start a new one.
If you've got pics from our old cruises and BBQ's, Photoshops, etc post 'em up! I'm trying to consolidate an archive! Lots have been lost though unfortunately :dry:
Standby for whatever galleries I could find on my old HD...
danny boy is back in the community...............
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
