Hi All
As most of you know, i had a bad front on and rid off my car, i final finished repairing it and when you start it up for the first 30sec - 1min there is a tapping sound, when the car gets warm the tapping goes away? any ideas? i was thinking it was the fan at first as the radiator was wrapped around it, but im not sure anymore?
Cheers
https://www.sau.com.au/forums/topic/119421-tapping-from-engine-until-warm/
how long has it been since the engine has been running ?
Did you change the oil ? If so did you go to a different oil to what you normally use ??
If you have not had the engine running for a while the lifters are probly playing up. Get some lifta free from your auto parts shop and run that in with a new oil change and filter. Should fix the problem.
spoke to mechanic bout this and yeah exactly what the guys have already said in here. Use a heavier oil, it goes away after a while because the oil level has to rise and lubircate parts something like this. If its still doing it while its warm and driving around and gets louder while accelerating then yeh thats a different story I believe.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
