A mate had a similar problem in his 34 GT-R. Turned out to be a cracked piston. On high boost, the boost would force its way past the piston and pressurise the sump and spray the contents into the catch can and out all over the engine bay.
Expensive engine rebuild solved the problem.
Oh dear! Same thing as i had.....
Broken Ring lands so no seal past the 2nd ring and it maybe crank blowby!
I hope not mate
Good luck with your findings keep an eye for blue smoke out the back and u may have to do a compression test.
U could try to Increase the Crankcase ventilation as GTStVSPEC says if your running 15psi of thereabouts!
Sorry didnt mean to double up just talking from experience..
All the best :uh-huh:
I had problems with this also. I did a compression test on mine and found cylinder 6 was right down. We tried a lot of things to try and figure out why. I actually found putting slightly thicker oil in did the trick. Seriously, this sounds dodgy but i swear, we did tests before and after, drove it nice, rang the balls of it, the whole works and never had a problem since. It would seem that the oil was too thin and simply draining away from the valves.
Hopefully you may find this to work. I am far and away, not mechanically minded so I have no idea why this works, all i know is that's the only thing we changed on my car and the compression literally doubled back up to normal afterwards.
Good luck!
macka,
What did you (the engine builder?) put your broken ring lands down to? Detonation I'm guessing? If so what was the cause?
Sorry to hijack - but I thought it might add to the thread info.
Nice 1/4 fig's to mate! They look very familiar :P
Originally posted by whatsisname
macka,
Nice 1/4 fig's to mate! They look very familiar :(
Thanks mate :)
Well the car came over with a boost controller that didnt work properly and it pinged straight away, my guess was overboosting detonation rather than lack of fuel.
Then ceramic turbo self destructed and that didnt help. soon after blue smoke....still went ok but we decided to chuck her in the shed and open her up.
sure enough 2 pistons had cracks in them.
Gotta get yaself some of them 12s whatsisname ;)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
