To put a thumbnail in
Go into add reply
Under the text window there's a button browse. click that, select the pic. hit upload
then go into the manage attachments pull down menu and click add into text editor.
click preview post to see if it worked.
post-2863-1181184400_thumb.jpg here's another one of mine next to a beaten up sil80
To get the picture displayed, you need to upload to an off site server like photobucket and then link to the image.
they don't come from factory with those indicators. When you get your cared complianced in Aus they are supposed to be put in.
I wish i didnt have them, they look like shit.
I might buy some new guards from japan when i get a full respray and not put them in.
To clear the above question regarding the side indicators on R32's it is my understanding that when compliancing these cars it depended on the person compliancing the cars interpretation of the ADR relating to the indicators.
Basically the ADR says that they are only required if at a certain angle the front corner indicator is not visible. But if you look at your front corner indicators they have a bit that protrudes at the edge with a second bulb. This allows the indicator to be seen from a greater angle to the side (and rear) of the car than would be otherwise possible. So some compliers obviously felt this covered the ADR while others were not certain and took the "its better to be safe than sorry" option.
Wow, I never thought I could right so much about something so small..... :D
hmmm sounds about right to me really
p.s. yidz are they R34 GTt rims ? they dont look over the top but suit the car nicely,
p.p.s. yes, getting ur front windows will look a LOT better :D
Yep GTT rims :) Theyr a nice cheap rim (even though they were on when I got the car!!) The hardest part is finding centre caps for them. I paid $130 for the 4!!!
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
