To clear the above question regarding the side indicators on R32's it is my understanding that when compliancing these cars it depended on the person compliancing the cars interpretation of the ADR relating to the indicators.
Basically the ADR says that they are only required if at a certain angle the front corner indicator is not visible. But if you look at your front corner indicators they have a bit that protrudes at the edge with a second bulb. This allows the indicator to be seen from a greater angle to the side (and rear) of the car than would be otherwise possible. So some compliers obviously felt this covered the ADR while others were not certain and took the "its better to be safe than sorry" option.
correct.
personally, id luv to rip mine off and fill in the holes...
Edited by 32line
Here's my Midnight Blue Pearl R32 GTR. I couldn't find any members rides or intro threads so I thought I'd post some pics up here.
A few minor mods so far:
Engine:
Apex'i intakes and pods
3.5' 5zigen exhaust
Suspension:
Apex'i N1 coilovers
Nismo front and rear strut braces
Wheels and Tyres:
19 x 9.5 Axis Deepdish in shadow finish with 265/30 ZR19 Nankangs
Interior:
Nismo 320km/h cluster
Momo Race EVO steering wheel
Nismo leather gear knob
ICE:
JVC DVD headunit with 3.5 screen
Pioneer 6.5 splits
Pioneer yellow cone coaxials
Kicker L7 12' square sub
Kicker 1000W RMS amp
Kicker wiring
Hope you'll like it. :thumbsup:
Travis.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
