To clear the above question regarding the side indicators on R32's it is my understanding that when compliancing these cars it depended on the person compliancing the cars interpretation of the ADR relating to the indicators.
Basically the ADR says that they are only required if at a certain angle the front corner indicator is not visible. But if you look at your front corner indicators they have a bit that protrudes at the edge with a second bulb. This allows the indicator to be seen from a greater angle to the side (and rear) of the car than would be otherwise possible. So some compliers obviously felt this covered the ADR while others were not certain and took the "its better to be safe than sorry" option.
correct.
personally, id luv to rip mine off and fill in the holes...
Edited by 32line
Here's my Midnight Blue Pearl R32 GTR. I couldn't find any members rides or intro threads so I thought I'd post some pics up here.
A few minor mods so far:
Engine:
Apex'i intakes and pods
3.5' 5zigen exhaust
Suspension:
Apex'i N1 coilovers
Nismo front and rear strut braces
Wheels and Tyres:
19 x 9.5 Axis Deepdish in shadow finish with 265/30 ZR19 Nankangs
Interior:
Nismo 320km/h cluster
Momo Race EVO steering wheel
Nismo leather gear knob
ICE:
JVC DVD headunit with 3.5 screen
Pioneer 6.5 splits
Pioneer yellow cone coaxials
Kicker L7 12' square sub
Kicker 1000W RMS amp
Kicker wiring
Hope you'll like it. :thumbsup:
Travis.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
