To clear the above question regarding the side indicators on R32's it is my understanding that when compliancing these cars it depended on the person compliancing the cars interpretation of the ADR relating to the indicators.
Basically the ADR says that they are only required if at a certain angle the front corner indicator is not visible. But if you look at your front corner indicators they have a bit that protrudes at the edge with a second bulb. This allows the indicator to be seen from a greater angle to the side (and rear) of the car than would be otherwise possible. So some compliers obviously felt this covered the ADR while others were not certain and took the "its better to be safe than sorry" option.
correct.
personally, id luv to rip mine off and fill in the holes...
Edited by 32line
Here's my Midnight Blue Pearl R32 GTR. I couldn't find any members rides or intro threads so I thought I'd post some pics up here.
A few minor mods so far:
Engine:
Apex'i intakes and pods
3.5' 5zigen exhaust
Suspension:
Apex'i N1 coilovers
Nismo front and rear strut braces
Wheels and Tyres:
19 x 9.5 Axis Deepdish in shadow finish with 265/30 ZR19 Nankangs
Interior:
Nismo 320km/h cluster
Momo Race EVO steering wheel
Nismo leather gear knob
ICE:
JVC DVD headunit with 3.5 screen
Pioneer 6.5 splits
Pioneer yellow cone coaxials
Kicker L7 12' square sub
Kicker 1000W RMS amp
Kicker wiring
Hope you'll like it. :thumbsup:
Travis.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
