what wheels are these? i love the concave on them... would look hot in white haha
heres my car before and after
theres how i bought her... looks pretty hot just bought coilovers and painted brake callipers with ame tracer wheels
origin kit and bronze xd9's tesfit now with drift wing
powder coated wheels white with green paint
will get better pics when i have some nice weather.... and some nice action shots as well
look like a Vertex to me... are they any different between these 2 kits?
They're very close to indentical, some very subtle differences. Most notable is the front bumper. I think the openings on the Vertex are a bit bigger. The FK one is a bit 'chunkier' for lack of a better word.
Edited by Mark_McQ
Looks sick bro. Whats the kit? I was thinking a mix, Final Konnexion and BN sports or similar. Let us know champ, sick R32 no doubt has some power too yeah?
sorry i couldn't answer your questions sooner guys i am working outa town with no computer acess
final konnexion is quite a bit different and BN sports is alot more big and open... BN sports is alot more similar to the Uras kit.
i love the final konnexion kit but live in Canada so it would be far too expensive to get. Oh and i don't have any power yet i actually get my RB30 block at the end of this month so i will be one of the only guys in canada rocking it. I will keep you guys updated oon some of the stuff i am doing i am putting a crazy roll cage in which you guys will die for. And also australlia does need better wheel fitment which is why i don't mind sharing wheel specs
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
