Thats exactly what i'd do when it came time to buy new tyres.........
haha true, but if you can afford to make the car look like that in the first place and then put it on a track it would be nothing to your bank account :)
nice one 4 pimpin ne specs mate?
Engine: RB20DET
Exhaust: BLITZ NUR SPEC
Suspension: UNDER CONSTRUCTION
Wheels: 18" STARCORP SHADOW CHROME
Modifications: Full colour change. Engine been rebuilt, PAR rods, ARIAS Forged Pistons, ARP main, rod and head fasteners, Head Ported. Camshafts yet to be installed, PT6176RE Precision Turbo Charger (680hp) equivelant to a Gt3782 but ball bearing 82mm front wheel, Custom high mount exhaust manifold and dump pipe. Custom Plemun Chamber, Blitz 700cc Injectors, PWR Intercooler, 57mm PWR Radiator, Microtech E.C.U., Sard Fuel Reg, Bosch 040 intank pump, Blitz IDC II Electronic Boost Controller, Battery Relocated to the boot. White Leather Seats and much more
Stereo Audio / Visual: Nakamichi Single Din 6 disc music bank. MB Quart Premiums
havent got a power figure as im still running motor in. heading somewhere in bout a month to get tuned. tuning it on nothing under 22psi.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
