i came...
lol too much detail
hi mate,
u've got new set of wheels again? i'm envy
Yeah man new wheels again hehe
haha no shit ey. Get's a new set of wheels, "oh I'm sick of these, I wanna get some kai's" hahaha :P
Nah it's looking good man. Get some larger pics up.
haha thanks man ;)
Nice work man that looks insane with the KAI's!
I f#$king love the look of it abu, and because your car looks just like mine, except i got the gtr bonnet, i'm about to cream my pants!
Good stuff mate!
bahahah thanks heaps man :)
Hey abu
any better pics mate?
Got the guards rolled a few days ago so need to get some new pictures up, R33 LCA going in this week and lowering it to a better height - here's a big picture of it though.
Abu.. your car looks pimp fo sho...maybe i come round tomorrow night and see how things are going?
Sorry for the extra late reply - but I'm sure you've been over to see it in the mean time :)
yea they are AME modelart
20x9 front and 20x10.5 rear
and just so people dont start shit the cars a GTS with complete GTR bodywork :P
have a look at this months HOT4s mag and Ignition DVD, its on the cover of both
and just so people dont start shit the cars a GTS with complete GTR bodywork :D
ah ok thanks. they look hot.
didn't realise it was a gtst though. very fat. nice work.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
