R32 Pix Only
gts-t 4 life
yea they are AME modelart
20x9 front and 20x10.5 rear
and just so people dont start shit the cars a GTS with complete GTR bodywork :(
have a look at this months HOT4s mag and Ignition DVD, its on the cover of both
Awesome. Getting the mag tomorrow so will be a good read :)
Got a couple of random shots I found laying around..
Thanks man. Yeah, down the track at some stage I'll be looking into it. I've spent all my money on the outside so my next aim will be to beef it up a bit under the bonnet. I have a GTR spoiler sitting in my spare room I've gotta get painted so that will be the first thing :)
cheers mate, dmd in brisbane did the body and paint. front guards are +25.
i told don not to worry to much about fit and finish as the car has had and continues to have a pretty hard life.
They are WORK Emotion XT-7's - 18x9.5
I duno what offset they are though cause I wanted to know also. When i can be bothered i'll check them.
*Edit* - I am pretty sure the offset is +12 though
Edited by r32line
So I take it that he was impressed with the inspection! Congrats on the sale!
A very nice GTR indeed. Keep it up.
Cheers
Yeah, first person to actually come and look at it bought it. Easiest sale ever.
Thanks.
oh you bought both of Alex's cars! You lucky prick, nice work man
    • Updating results.  Using ATR45SS-0 model VS UHF57-900. Those two are very different turbos, different wheels sets with different wheel hub profiles but yet with almost identical result. I’m intrigued with both turbos performance. ATR45SS-0 was a 61mm turbo first developed in May 2020, UHF57-900 was a 62mm turbo developed in March 2024 as a powered up alternative of a G30-900. On paper ATR45SS-0 maxed at 563rwkws, while UHF57-900 maxed at 568rwkws. ATR45SS was slightly more responsive with slightly better power band through the mid range.  Road driving ability, ATR45SS-0 had better throttle response, felt more robust under throttle, as it wakes up earlier. I think G series wheel hub design made it to have higher inertia under light throttle. Doing bit more prototype work in the next few weeks, will update result when its back on dyno again. ATR45SS0 Blue, UHF57-900 Red Chequered tuner's Dynapack hub dyno, E85 fuel. Mod list is in video below video_20240604_114214.mp4
    • Did you run the power cables for the mac valve to the other side of the car near the fusebox? Utilizing the stock boost controller cables? or did you run new ones?
    • Hey I have a potentially stupid HICAS question 🤣 I'm currently doing a full hicas delete, Power steering pump modified to non hicas, all lines removed from the car along with all electronics. My stupid question is - Do I need a lock out bar? is there any reason why I cant just remove everything from the rear end? I already have a lock out bar but thinking to save a few extra grams I could also get rid of the arms and tie rods as well and just run it with nothing in its place? or would it have a negative effect on handling?
    • Hi how are you guys?  I know i have been absent for years but im coming back slowly guys just wondering if anyone know where the ball joint on the NISMO arm front and rear can be replaced with OE parts?  Also  i know this is not the thread looking for springs and blistein shocks for the 260rs. Please advcie     cheers    yudy
    • Hi i do you have for stages 260rs?
