yeah i got hold of a gtr bar but wasnt happy with the quality though it was good for the price paid. Ive since priced a gtr one from nissan (should have done so in the first place) and am going to just buy one new. Cant decide if ill paint the lower lip the body color or not, thoughts?
body colour!! :thumbsup:
although I have black.. but I'm over it
Thanks guys, I love it!
I feel so much more satisfied with these wheels than I did with the CR KAI for some reason
Handles awesome now, can throw it in and out of corners really well!
Tires on the rims weren't what I was promised so I will probably replace them tomorrow with a brand new set and something not so stretched, currently running 215/40 on a 9" rim :down:
Looks tough. Should leave the wheels silver as well. Don't go black in my opinion. Go everything silver, silver lip and wheels. :down:
Yep I don't want to do them black anymore, looks awesome in silver - you have to see it in real life! The picture are taken off my phone and look shit
I'm starting to like the lip again in black though, matches the cooler and doesn't make the car look really really low like it is - looks tuff from the front when its coming towards you
I didn't even see you online, talk on MSN
EDIT: your not even online thats why I didn't see you on MSN!!
LOL! I was on msn, went off after I posted that reply. hahah. I'm on now man. You're always on away so I don't know when you're there!
Car look nice with 33GTR wheels, Abu. suit the car alot and even better with GTR front bar/lip
once again, good job mate! and u just make me wanna go back to 33GTR wheels on my car!!
:rofl::D:(:):thumbsup::thumbsup:
haha thanks man
They have really good fitment for a 9" wheel - I love the way 17s sit
bastard! lol
looks awesome abu! do you get much attention for the off centre number plate?
Thanks man
Na, haven't had any problems with the off center number plate at all.
Police have seen it many times but have never looked twice really - I don't find it a big deal really as most if not all MITSUBISHI EVOS come out factory with plates mounted on the left side of the bar so shouldn't cause any issues legally I believe
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
