Tried a secret new way of detailing engine bay. I think it came up pretty amazing. Love a nice clean car :(
p.s awesome colour & wheel choice player_hater.
whats the secret new way you detailed your engine, im bored i feel liek detailing mine but just dont know what to use, pm me if you can, by the way nice clean engine bay mate
cheers tony
player_hater- nice car mate, wheels look nice aswell
LOL I just gave it a good hose down, then wiped over everything with warm soapy water, then wiped it down again with an old (clean) rag, and then used some tyre shine on the black rubber parts, then let it dry for an hour or so...
If you look close enough, the IC piping and strut brace still need a good polish but that can wait til later on.
Edited by NoFX_Hardcore
tire shine :O:O:O:O too oily and with the heat it spreads everywhere and makes an ugly mess. do the washing and wiping part make sure u do a good job cleaning all the grease and oils off and then after blow the engine down with the compressor (be carefull around the electronics) to get rid of excess water build up let it dry up good and then silicone spray it!! trust me its the best and only way it should b done :domokun:
tire shine :):):D;) too oily and with the heat it spreads everywhere and makes an ugly mess. do the washing and wiping part make sure u do a good job cleaning all the grease and oils off and then after blow the engine down with the compressor (be carefull around the electronics) to get rid of excess water build up let it dry up good and then silicone spray it!! trust me its the best and only way it should b done :)
Oh will have to try that one next time. As for the tyre shine, it still looks great now after driving around for the night so maybe its just with different tyre shines. I only used a fairly no name brand one? And not the foamy one lol.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
