LOL
but I bet my offsets, widths and sizes are better
Paint them black then put them on! I'm tempting to paint them black, I reckon it will look tuff on silver
i must be told wat rims these are??
post-51411-1215678172_thumb.jpgpost-51411-1215678236_thumb.jpgpost-51411-1215678272_thumb.jpg
this is my new baby just waiting on turbo and high rise to arrive for a bit more power.
Im pretty bored so i just thought id put some pics up
The difference between standard boring wheels n nice exciting wheels
travis to tell you the truth i really like the way your car looks with the standard r32 gtr wheels, doesnt look boring at all but your wheels look pretty good aswell mate, do you mind me asking how much you picked up your wheels for,
cheers tony
cheers tony
yeh it looked good when it was clean with the tiny wheels on but once it gets dirty they make the car look really bad ay
lol jetgtr thats exacely what i said, if they were 18s i would piss any wheel off and go for them and abu your getting everyone jealous mate so just stop showing your car off hehe, guys we should organise a cruise with all our skylines sometimes and if yous want on september 12th wer all going to calder park to run our acrs so anyone just pm me if they are intersted in comeing along and having some fun,
cheers tony
yep Uras NS-01's
17x8 front 7 17x9 on rear
+30 offset
Too many times people refer to them as drifteks :)
are these the same one you get through just jap?
im thinking of getting a set to put the semi slicks on for the track, are they any good?
they're hot i like em...pm sent rekin
hehe pm replied
yes they are exactly the same as the ones Justjap sells, although ive heard that they have run out of stock of 9inch wide and only have 8inch available
    • Your other option is to buy a spray can of hi-fill and prime it with some pinholes. See if the primer makes them disappear. If it does, then you can leave it with pinholes of that size and they will go away when the painter takes over.
    • Ah ok. I seem to be mixing it like everyone else does so not sure what's happening. Will experiment with it more.
    • Depends on what you mean by OK. First up, was this done cold or hot? Are they reasonably consistent? Yes, they are reasonably consistent. Could be better. But unless it has had a build at some point, it is a ~30 year old engine and you'd expect some variation. Some of the difference could also be in user technique Is it good compression? Well....not numerically, no. New they were >160 psi. The one at 140 would be fine, in that context. If they were all ~140, you'd be reasonably happy. But the one that is @120 is twice as far down from the original numbers as the one @ 140. But.. (again)... technique can play a part in the absolute magnitude of these numbers, and the quality/state of repair/accuracy of the pressure gauge is not known. In the context of the above, the compression tester that was used last on my car is regularly compared to a known good pressure gauge. Not calibrated, exactly, but compared to a reference instrument that is not used for any other purpose, so cops no abuse. So we can trust the measurements off that tester. But another tester in the same workshop wasn't being compared against the standard and was reading a good 30ish psi lower. When you're reading 100 psu but the engine is really doing 130, you can make bad decisions.
    • More likely from tiny bubbles in the filler/putty. Maybe be less aggressive when mixing it. Perhaps invest in a vacuum chamber to pull the air bubbles out?** **I don't know if this is a thing for body filler. I see hardcore epoxy makers degassing their mixed resin on the regular.
    • IIRC, the speedo on these is fed from the sensor in/on the snout of the diff.
