noice. where in canberra did you take those pics?
There's a boatramp in the carpark that's next to the boathouse restaurant.
Took me ages to find somewhere but I felt I had to take some since Siknis from CC detailed it for me yesterday!
nah you dont need GTR gaurds to make the front bar sit nicely, simply redrilling/grinding 2 wholes in the GTR reo bar (12mm to be exact) will bring the front bar foward enough to fold the sides of the bumper up to the gaurd leaving no gap and over hang :D
What does the gap with the headlights look like with this approach? Very clever by the way :)
.... but to bad for the 20 in the R32 :D
Because you never went in a properly modified example :) Should have wound up the 2535 to 240rwkws, from there and higher they start to feel decently quick :)
haha I wanted 230rwkw but yeah it wouldn't get there which just made me not want to keep it/modify anymore, especially after all the work/time I put into it with all the good parts
Most Trent (Status) could get out of it was around 215rwkw on 1.2bar, it wouldn't go any more. Drove great, had plenty of power and was fairly responsive for a 20, probably because of the cam gears but still didn't do it for me
After all those mods and money spent I could sit with my cousins stock R32 GTR, with cat back exhaust, chipped ECU and pods :D
My GTR now blows that, stock with exhaust, PFC and 14psi makes around 260kw at all 4. They just don't compare, even if it is an R33 :)
I still love it, always will! You just can't beat the look of a clean R32 with fat wheels but performance wise, you can't go past a GTR :D
That's my story
Well curse you because my XD9s look hopeless on my car compared to yours. So just bought some RE30s, hopefully they look ok, if they dont i dont care as i just want some nice light wheels that fit :D
bahaha I noticed they were for sale
Where did you get the RE30s from, are they good size/offsets?
They better look like these
Didn't you have RegaMaster wheels before, they are fairly light in decent sizes?
Yeh the Rega are an awesome wheel and the same weight give or take as my old LM GT4s. Only prpblem is the spoke design and offset of mine mean they dont clear larger aftermarket brakes. The same problem as the XD9s, fine over std brakes, not so flah without spacers if you want to run track brakes.
The RE30s are same as my XD9s, 17 x 8.5 + 30. According to Rays they are suitable for bigger aftermarket brakes on a Skyline, and have a better spoke design to clear calipers. Would love to go the sort of offset you ran on your GTSt but i need the suspension travel and gaurd clearance on the track.
LOL, yes. Next years GP i might try and steal some Rays wheels out of the Williams pit garage :)
hey guys last night i was pretty bored so i reversed my car out in the drive way and here are the ne wheels on it and yes thye are SSR PROFESSOR SP1,
they are 17+9.5 all aorund with a +12 offset, tyres are bridgestone potenzas re-01s with about 70% tread and here how the car looks now, ive just slapped them on and havnt touched it yet as i just put them on yesterday but yer they look really nice, sorry for the pics are pretty shit but will get better ones soemtime dutuing the week
they come out pretty nice but i can always get that really fat ass look by going a tyre like 275 or even 255 but i think i will stick with the 245 as they are spot on and still look fat and stocky on the gtr
car needs lowering liek big time but was going to do it tonight but i think looks liek ti will be tomrorow or wednesday but will keep yous guys informed but here is some pics of the wheels on the gtr
cheers tony
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
