This is what it's like in Canberra today - Just put it up as my desktop background - nice and calming. wish I had put my grill in today but gotta do the AC regass so easier to leave it off till nxt weekend.
can i have ur front indicators lol theyre so hot
just one question with all do respect what entice's ppl to destroy their rear guards on the nice gtrs?
who knows, maybe for the same reason your GTR is slammed and running the body-kit/wheels it does?
a lot of different tastes on this site
Here is mine.
Currently getting a engine rebuild which should be finished in the next week or so.
I also have a build thread as well if anyone is interested
Looks absolutely awesome!!!
Love how clean it looks....just the way a r32 should look
complete side skirt.
previous owner had tried to make this car look like a N1.
But I wasn't a fan of all the aero parts on the car so removed the bonnet and boot lip and left just the skirts and rear pods.
looks good man, i was very close to getting the skirts and rear pods but i got a picture preview and it changed my mind, but ur one looks good with it , maybe its the photo that i recieved that turned me off..
didn't really wna kit up a gtr tho they look beautiful standard. but im in love with the vspec mudflap looking thing.
I felt it filled out the gap for the 32's and for a GTR you don't really want to go any other type of side skirt other than a N1.
but that's me personally
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
