thanks.
I believe the rear pods are factory nissan/nismo/n1.
and the lms are factory black.
love my wheels.
that was back when the paint was first done.
approx 5yrs ago.
dont know if it shows, but when it was yellow, it had virtually no clear on the roof.
I now hate my type M pods...
  • Like 1
black - my 2nd gtr
red - my 3rd gtr
sliver - my current gtr (which also took the spot as my 1st gtr as i bought the car back)
yes - i am a sick puppy :)
Those are 3 awesome looking r32 gtr's!!
What wheels/sizes/offsets are the ones on the silver one??
