Trust rear pods ?
Looks like ones I just bought
Never mind found answer :wacko:
Rear tyre/rim combo not quite flush. Seems guard is rolled tho
Whats the rim size/offset and tyre size ?
1064015_10152039259404202_699712247_o.jp
Got my HKS Super Dragger, Nismo trunk lip, and GReddy rear spats installed.
Edited by Sinista32
