Hi Guys,
Apologies if this is in the wrong section...... I wasn't sure exactly where to post. I thought this would be a good starting point :)
I bought an R32 GT-R imported from Japan about 5 months ago thats a complete lemon. Its been mostly sitting in my garage, and that of a pannel beater who went out of business recently, waiting for various things to happen. Luckily, the guy in Japan that I bought it from is doing the right thing and helping me with getting it to an acceptable state.
I need some recommendations for workshops in Perth to do the rebuild on the engine, as well as the rust repairs.
Problems with the engine include:
Noisy valve train - noise is most evident when parked, in neutral, after warming up, gently reving the engine up to about the 4000rpm mark, a noise like a flapping heat shield seems to be coming from the rear drivers side of the engine. I've had a good look and there dosn't seem to be any loose bits that could be causing this noise. I've pulled the rocker covers off and all the bolts/nuts for the cams are all torqued up correctly. I've also checked the clearance between the cam lobes and the tops of the valves and they are mostly ok, however there are a couple that are about 2-3 times the tollerance out. I have doubts as to if this would be enough to cause this noise.
Cylinder 3 is as oily as anything.
Compression is all over the show:
Cyl1 - 160PSI
Cyl2 - 155PSI
Cyl3 - 170PSI
Cyl4 - 150PSI
Cyl5 - 135PSI
Cyl6 - 155PSI
4WD system dosn't work. (pretty open ended problem, I know)
Pannel beater who was originally going to do the work on my car before going out of business said that there was some noise from the bottom end.
Gearbox has a noisy bearing on the input shaft (i've sourced a recently rebuilt gearbox to solve this already).
On the rust side of things, there are rusted out holes right the way through the floorpan on both the drivers side and passenger side, front and rear where the jacking points are located. I suspect based on the fact that all the metal underside around these points is pushed up and deformed that the previous idiot owner in Japan has no clue about using a jack!
It seems at this stage that the guy I've bought the car from in Japan is looking to cover the cost of labour on the engine rebuild and I may have to either partially or completely cover the cost of parts.
At this stage, I'm not looking to spend a heap on the engine internals. I simply can't afford to currently.
I'm guessing that as far as the engine rebuild goes, I'm up for a full set of bearings, valve guides, rings, potentially valve springs, gaskets, timing belt, other belts, hoses etc and other incidental bits during a rebuild. I'm also thinking that it may be a good idea to put an uprated oil pump in place as I've heard many times about the oil pumps on the r32 GTRs shitting themselves. Nengun have a Trust oil pump for $1200. Are there any other relatively inexpensive things I should do to the engine at this point in time to make it more reliable, or able to handle more power?
I'd really appreciate any recommendations that anyone can give me on local workshops in Perth to do the engine rebuild (or workshops to avoid for that matter), or pannel beaters to fix the rust (and likewise to be avoided).
Cheers,
-Shaun
https://www.sau.com.au/forums/topic/119784-lemon-r32-gt-r/
Damage control in maddington for panel repair work are about the best i have heard of for skylines and Top Racing in bentley for mechanical side of things theyare both in phone book ( steve at top racing is a gtr guru)
https://www.sau.com.au/forums/topic/119784-lemon-r32-gt-r/#findComment-2207436
I see another who has jumped onto the the cheap gtr bandwagon and been burnt.
I always tell people don't spend all your money on a 15 yo car and not save any for repairs. Cheap cars are espcially bad - you get what you pay for.
Now, to fix it - having to rebuild the motor is probably not a bad thing. just like with any other 32, most of them are f**ked. so at least you'll be guaranteed a good motor.
Also, most of the 32s i've seen haev a bit of rust, especially the ones from the north. if it's not too bad, then repair it.
All in all, it sounds like the car was really cheap, so even after repairing it, you will probably still end up pretty well off.
https://www.sau.com.au/forums/topic/119784-lemon-r32-gt-r/#findComment-2207441
2-3 times the tollerance out!?
RB26 valve clearence is quite large to begin with - ex .38mm (.015") , in .45mm. (.0177")
If your clearences were 2-3 times this it would sound like a diesel!
post up what you actually measured....
You dont need a $1200 oil pump unless you are chasing big power/ high rpm.
Just get your r32 crank modified using a collar that has a wider oil pump drive on it. (proengines from here makes them) and use a r33 oil pump or an N1 pump.
Good luck with ya rebuild
https://www.sau.com.au/forums/topic/119784-lemon-r32-gt-r/#findComment-2207621
Hi All,
Thanks for your replies...
Thanks gazza750... I'll give them both a call on monday and have a chat.
Yup. However, the vehicle wasn't cheap... it was just shy of $16,000 australian before import duty, ompliance etc etc. Based on the photos and the description, allegedly 60,000km, seemingly genuine, supported in every way by the rest of the description and photos etc, I assumed I'd managed to score something really worth having. However, it turns out not to be. This vehicle was several thousand more than the other vehicles available at the time, all of which had more realistic milage of anywhere from 100-160,000. I suspect mine was at 160,000km (doing hard miles at that) and the odometer was simply wound back.
Genuine Nissan GTR N1 Oil Pump Price: $499
Upgrade oil pump for RB26DETT
JustJap.com
Thanks Mr Italy!... Sounds like this one is the go-er then :D
Thanks CSRB25DE. Unfortunately I took the measurements about a month ago and never recorded them. So this is the likely the cause of the noise I'm hearing.
I guess the moral of this story is never buy a car sight unseen, especially if its in another country.
Does anyone have any more workshops or pannel beaters to recommend?
Cheers!
-Shaun
https://www.sau.com.au/forums/topic/119784-lemon-r32-gt-r/#findComment-2208326
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
