  • Replies 47
I'm going to BD4s to get my F-CON tuned... basically I have no choice but to go there as they are the only ones in Australia who can tune it :)
I've been in heaps of contact with Tom there and I'm happy to say that he'll give you all the time in the world with questions etc. Very nice guy to deal with.
My tune is on June 22, hope it goes well! Looking close to a $2k bill though :)
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2209101
Hey thanks for that Stan. BD4s would be good coz i live in the next suburb. Are they considered pricey, do they insist on using HKS stuff or can you supply your own stuff?
Oh and anyone used MRT performance, i know they do amazing stuff with evos - anyone with a skyline use them?
Thanks
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2209134
I'm supplying all my own gear bar one or two harnesses that I can't get myself. As for the HKS comment, then it's up to interpretation... they are the authorized HKS dealers in Australia so I would assume they'd be trying to push for their items being used :)
I wouldn't say that their pricing is expensive, it's just on par with all the other names out there.
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2209187
Well according to HKS USA both places are still authorised dealers, but BD4s is also a Pro Dealer, which means they have access to the tuning software for the F-Cons.
I've had a car tuned @ BD4s, they were on the level with me and pretty helpful. But your best bet is to talk to both of them and see who you're happiest with.
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2209881
Just thougt I might add that Performance Wholesale will direct you to BD4s for all F-CON enquiries... BD4s have access to information on that product that no other place in Australia will have - that's coming from another dealer so I guess it can be taken as true!
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2209891
Anyone had any experience with either CRD or BD4s in Sydney for a R34? Do they only use expensive brand name stuff or is better to go to small tuner? This would be for minor mods - basically keeping stock turbo.
Anyone use Bankstown Muffler fit as well?
Thanks
What engine management are you using?
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2210762
Talk to both and use who you are happy with. nNver used CRD, but did use BD4s for a good many years and whilst owning 3 Nissans,
They were a very professional, honest workshop, who did not take short cuts and where good mechanics as well as a good performance workshop.
have found so many performance places arent the best mechanics and only know how to half heartedly throw crap on cars in the hope they go quicker and fingers crossed dont blow up...forget fault finding, servicing etc to get a good reliable car
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2210854
bd4s are authorized hks headquarters..no contract lost
cant go wrong with either...
if you have a street car use bd4s if u have a monster use crd
both charge a fortune but worth every cent...i used bd4s for the last few years and had no probs at all...
ps. yeah its brell..brell designs 4s...
Edited by thizzle
https://www.sau.com.au/forums/topic/119939-crd-vs-bd4s/#findComment-2223147
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
