Well done Neil, good to see another GTR having a go on the track, great time aswell!!
I think your talking about the black R32 GTR you almost collected (BBGTR)...
Ooops - right colour, wrong model - BBGTR did express some relief after that sprint session - it was amazing that there was no serious damage done
  • Replies 105
Posted Images
GTR - Supercalafragilisticexpealodocious Cheater
GTR - Alcon Super Duper Cheater
GTR - Buy yourself a socket set Cheater
GTR - Quick to learn Cheater!
Sorry, GTR Envy ;)
Prophet Budge...he speaks the truth yoh!
And nice to have met you Neil. Hope its something simple with the car.
Sorry, GTR Envy ;)
It's standard man. A standard RPM setup.. :dry: Shame it was raining when you were down on the flag point. I didn't want to tempt fate by barrelling into Dandenong Corner. Lots of nasty things to hurt the car...
Did anyone get pics of the day?
:D
It's standard man. A standard RPM setup.. :rofl: Shame it was raining when you were down on the flag point. I didn't want to tempt fate by barrelling into Dandenong Corner. Lots of nasty things to hurt the car...
Surely there are some pics floating around.
And if that was you showing restraint into Dandy? It still looked absolutely awesome under brakes. It was one of the few cars not pinching brakes.
Which reminds me ..Matt, stop locking rear brakes :rofl:
locking rear brakes? you talking about me?
i dun think mine were locking.. i have doubts about by bias adjustment, but i reckon the rears are not even working...
i may have got a bit of comp lock up from those massive revs comming down into second :D
and also the smoke comming from the rear was out of the exhuast pipe not the tires...
the old BOV was mucking up the AFM good...
ne hoo... great day, had a blast..
got my times down to 1:35.07 best.... over 2 secs better than last time, and on a less grippy track...
not much but a start.. so i'm happy...
MaT
I'll say. bwwwhahahaha
Did you even get any indication of what caused your spin?. I couldn't believe I was facing the wrong direction, at such low speed and minimal throttle? I'll be storing that one up for next time :blink:
Regards
Andrew
Edited by BBGTR
Oops too many Matts. GTTR34 was locking the rear bakes everytime into Dandy...nothing major but it seemed pretty consistant.
As for Corona Matt, it seemed you needed all the engine brakign you could muster to stop the old girl...but a 1:35 flat is damn good considering your tyres and everything. I think its quicker then most of the R32/33 guys :blink:
As for Corona Matt, it seemed you needed all the engine brakign you could muster to stop the old girl...but a 1:25 flat is damn good considering your tyres and everything. I think its quicker then most of the R32/33 guys :)
lets not get too excited...
1:35 flat :blink:
my handbrake warning light is on consistently now... might have to check that out.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
