  • Replies 263
Posted Images
Anyone who can finish the Schlachtplatte, takes the car.... AND my respect.
Word out homes! Peace to yo motha.
Schlachtplatte
Löwenbräu's Platter – Selection of Bavarian Specialities, sausages, meatloaf, chicken schnitzel, roast pork belly, kassler, mashed potato & sauerkraut
what the hell is kassler??
as for sauerkraut *vomit*
the rest sounds yum :)
hahah caine normally id sit next to her but not when mussells are involved....I love them too....but she gets very protective of her mussells.....hahahaha I dont wanna get bashed again !! :mad:
meh as long as she doesn't get too affectionate with a mouthful :P
I'm veyr drunk atm, so forvige me, but are you confiusing Lownebrau with Bungalow 8? :D
haha yeah thats what I thought at first !!!
But ive never been to Lowenbrau so I resisted the temptation to comment !!
i may be actually confusing the lowenbrau with the belgium beer bar?!?! lowenbrau is the german one right? i say we move it to the belgium beer bar! :P its only around the corner from the lownbrau!
Booking confirmed guys.
7:30 Saturday June 24th :)
Bring it on!
Anyone who isnt on the list on the front page MUST confirm with me within the next two days if they want to attend, as the Lowenbrau needs final numbers.
If your name isnt on the list, a spot for you hasnt been booked and you will miss out.
I will pm each person who has confirmed attendance to provide details for payment of your deposit ($20) which will need to be paid by the end of this week.
Thanks all
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
