  • Replies 263
Posted Images
Well thats good coming from you and your not even attending so no fingers thanks LOL!!!!!!!! :spank:
Well I didnt see N1GTR but if you got other stuff on cant be helped a shame tho Ill have a couple of drinks for you more like heaps hahahaah
Saturday will show the men from the boys
Hey there are females attending you know!!!!! :spank:
I do hope you have your drinking hat on NXTIME hahahahaaha should be a great nite this is our second time
Yeah you will be taking over the chair breaking wont you ando hahahaahaah
Hardy har Jess..... :D
The only thing im taking over is my soberness and entering a state of bliss consumed by glorious food and copious amounts of beer :)
What happens in this 'state' is anyones guess :PBJ: :D
Disclaimer 101 - I am NOT driving and endorse the responsible consumption of alcohol................ :spank:
Hardy har Jess..... :)
HERE HERE !!!!!
Hey im only kidding everyone picks on you so thought I would join in but so with you on drinking and eating glorious food...... :D
Going to be a awesome nite great you are still in but when do you pass up good beer and good mates hahahaah :D
Your cool I like your style :D
Guys...
My mate mentioned that the Lowenbrau was hosting a screening of the Germany - Sweden match on Saturday night and charging $25 entry to see it.
Something to keep in mind, not sure how it'll affect dinner.
Already covered Andrew.
They called me today and advised that *technically* non ticket holders need to be out by 11pm, but they will let us continue until midnight, plenty of time and a few people plan to kick on well into the night :)
Hardy har Jess..... :banana:
The only thing im taking over is my soberness and entering a state of bliss consumed by glorious food and copious amounts of beer :dry:
What happens in this 'state' is anyones guess :PBJ: :banana:
Disclaimer 101 - I am NOT driving and endorse the responsible consumption of alcohol................ :D
uh oh! LOOK OUT!
Be careful ando, you wouldn't want to get yourself into any more bets you can't handle now would you?
They called me today and advised that *technically* non ticket holders need to be out by 11pm, but they will let us continue until midnight, plenty of time and a few people plan to kick on well into the night :dry:
Brilliant :D
When they kick you guys out - its an easy (albeit slightly uphill) drunken stumble to Mens Gallery;)
Men's Gallery?!?! What are you, some kind of sicko perv???? :D:O
I'll meet you fcukers there :P
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
