  • Replies 242
Hey Nastazia...is the tank empty though...ie when you fill up how many litres can you squeeze in? Reason I say that is the fuel senders in the 33 can be a bit dodgy sometimes and give a false reading. Should definitely be getting more than 250km in a fairly stock skyline.
Well I mean, I've only ever let it run onto red light once in 6 months or so... so I never fill it up from scratch. If I granny drive ALL the time I will get about 280 but yea It's pretty sht seeing as I live in the Vines and do around 500 - 600km per week :D
https://www.sau.com.au/forums/topic/120328-fuel/page/2/#findComment-2220050
Tell you what.... next time you fill up keep a check of the actual litres you put in......it is a better way of telling how far you have gone on how much fuel. On mine when it is reading 1/4 left I usually still have at least 30-35 litres :D
https://www.sau.com.au/forums/topic/120328-fuel/page/2/#findComment-2220207
once i cleaned the AFM on my old 33 gtst i got 600-620 / tank!
in the GTR im lucky to get around 520-540 / tank
600-620!!!! man i think i might see if that works on mine, i useually get 400-500 from a tank and thats about a 50/50 mix of highway and city (with the more than occasional thrash) driving using vortex or mobil premium, long distance best i got was just under 10L to the 100
https://www.sau.com.au/forums/topic/120328-fuel/page/2/#findComment-2220648
this is the thing though.... how many people really get a skyline from japan....change the O2 sensor, clean injectors, clean afm, perhaps clean throttle body...if we all kinda started from a similar starting point engine care wise...we could all be similar perhaps
i havent been through a tank on the 34 yet..but its looking to be about 450...but thats the first tank of heavy right foot driving..
https://www.sau.com.au/forums/topic/120328-fuel/page/2/#findComment-2220943
^ The general answer would be yes, but all performance cars are on the rich side to be safe. From just one personal experience where I seen it first hand, I was behind Topaz when he put his foot down & he blew black smoke, I did as well and in my rear view I seen it as well (not letting a gtr get away easily now :)). If black smoke is coming out under normal acceleration, then you worry but otherwise for the type of car it's normal.
https://www.sau.com.au/forums/topic/120328-fuel/page/2/#findComment-2224299
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
