  • Replies 242
I've got an auto as well and manage to get 400km on a tank before I cave in and get some fuel, at this stage it's been sitting just above the 'E' for a while now. This is done on 'grandpa' city driving with full exhaust, FMIC, EBC, pod and piggy back ECU.
I used to only get 250km's from absolutely-full-tank to just above the 'E' mark. I just changed my O2 sensor and then I could reach the magic 400+ mark, then I got my ECU tuned and things seem to have improved a little more still.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2474655
cool thanks :P yea had my oxy sensor done 5 000km ago too
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2474989
hay guys, i replaced my 02 sensor today with an NGK item, and i had a long discussion with the bosch guys down here in tas. THE EL FALCON O2 is not anywhere the same, but somehow it manages to work, the heating element is different, and the output thershold is different.
I have noticed a BIG difference in the NGK item, the sensor is simmilar to stock but has different inside parts. I also replaced the ECu temperature sensor, the car is sooo much better now, going to see how it goes with the fuel economy.
I also replaced the plugs gapped to 1.1mm and i have to change them back to .8. It deffinatly pulles better with .8's
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2475702
I put in $50 or 34L on Wed and got 250kms out of it - (run down to red light). I have an auto fairly stock 33 running 190HP on stock boost... Is anyone else in an auto getting the same?
Gees! you must thrash it round! ;) I always get over 400kms, today I got 430 odd! (auto)
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2476026
' date='8 Sep 2006, 09:28 PM' post='2475808']
how big is an r33 gtst tank?
i fill up around 270-300km and i get around 40L in
thou im running over 300hp with 11:1 afr, and hit the limiter constantly on most days hahha
Should be about 65L tank, and you should stop puttin that foot down so much man ;) I got 58L in mine today, I did run it down bit more than usual.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2476027
Should be about 65L tank, and you should stop puttin that foot down so much man :) I got 58L in mine today, I did run it down bit more than usual.
ohh thanks for that pulp ;)
i think i can push it alittle bit more than to 350km... my fuel gauge doesnt work the best so i dont want to all the sudden run out of fuel ahaha :)
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2476037
I get around 450km out of 50L with my RB30E+T only mods are 3" catback and pod, I'm pretty happy with that, it's f**kall, if anything more than when it was NA
I Just filled up my car for the first time with the rb26 in and only got 235 kms out of the tank!!
i was shocked my fuel consumption halfed from the rb20. Im still running it in so i wasnt thrashing it. Im running a microtech ecu, is something wrong? do i need to retune or is this the reality of an rb26 running 310 rwhp ?
It's the Microtech, it doesn't have closed loop (unless new ones do?).
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2477374
closed loop? whats that?
Its the Lt 1200 model. running MAP
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2481342
The O2 sensor controls fuel mixtures when cruising, to give good fuel economy, The Microtech doesn't use this and is rich all the time, not just when when flogging it, not flogging it would still use less fuel but not as much less.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2486675
Arr ok. Interesting.. Wish i knew that before haha.
have spoken to someone else with a rb26 running microtch and they are getting mor like 300 km/tank heading back to rotomotion for a retune i think, unless anyone would recommend someone else who knows microtech well.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2488059
play r 32, you should probably invest in a wideband sensor like this
Although you don't have closed loop, you should still be able to adjust your fuel maps so that when your cruising your sitting on an AFR of 15 or so to conserve fuel. Just get a mate with a laptop and go cruising :happy:
I'm guessing your tuner probably only did a WOT tune if your using that much fuel :laugh:
EDIT: Just forgot, my record so far is 8.9L/100km with a fair bit of nanna driving. I got 470km off 42 L... gotta love the RB20 :laugh:
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2539536
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
