As the topic states, Auto Salon is back in Adelaide on the 12-13th August.
There are several cars in the group that are worthy of entering (not that I expect we will win King of Autosallon) and I wanted to know if its worth setting up an SAU site. Entry is $100, (less than a tank of petrol), and we need a minimum of 6 cars for a club display.
If your car is up to the job and you can spare the time to clean and polish then set up on Friday afternoon (3pm -10pm), add your name and details here. We tried this once before with mixed results, so this time I am suggesting people will nedd to be sure by the end of June and cars will be entered on the 1st of July (payment required)
https://www.sau.com.au/forums/topic/120426-adelaide-auto-salon-august-2006/
Might be worth pitching in for a banner too.
And guess what? Darren works in Printing: http://www.skylinesaustralia.com/forums/in...howtopic=120286 :mellow:
Oh and i think I'll keep my dunga OUT of this. Might be able to come by and help setup though.
Edited by Oosh
i'm keen, do you know the cost of entering plus dyno runs?
The only problem i can forsee for myself is that i work arvo's so setting up on friday could be difficult for me but i'll try and work something out!
If the car is ready in time then I am in - put me down as a 'yes' and I'll update prior to July 1st
My plan is to take the Friday off to prepare and set-up my car and then I'll help others as required.
No offence intended Mr. iNFMS, but it's SAU or nothing for me.
the r31 club had a smallish display last year
banner - best bet is to speak to Ted Turner Signs at Edwardstown as they did ours for around the $160 mark i reckon - and thats a 2000x1000 vinyl banner
dyno run is included in teh entry cost, dB drag racing is extra and ya gotta enter somewhere else
Well a few Skylines from my mechanic's w/shop are comming up to enter this year, as they just missed the Melbourne A.S. Would you allow us to join your stand? If i come i think there will be at least 4 Skylines.
Not sure if they want to enter on their own though, so i will keep you posted : .
i could b up 4 it, but ill know closer to the date cos might have somthing on....my car would need a bit of work done 2 it, the front kit is all hacked up at the bottom and i gota fix my lights cos they moved and clean my engine bay....actually clean the whole car...haha
I should be able to put my new car in:) as for dyno comp yeah may put mine in.
did u bought the 32 GTR from Kasai??
the car in yr avatar looks like it
looks like we got the number
now Matt/guy can collect $100 from each of us to ensure the club display will FINALLY happen this year :PBJ:
This is looking good so far this year.
I dont have a problem with other skylines fron Melbourne joining with us and it may even help if the Vic chapter of SAU (are u guys a propper club?) have an SAU banner we could borrow for the weekend.
The other aspect of a display is what sort of display will we set up? The entry form says a minimum is some sort of ground cover.
Any Ideas for a theme?
SAU VIC is the biggest chapter of SAU :blush:
Just spoke to the guys and they are entering as their own club "DRAGON". Not sure if i am going yet, but if i do i will prefer to enter with SAU :), i will keep you posted..
Jameszilla (James) is the person to PM for the SAU VIC banner. We also have merchandise :), nothing better than representing your club by wearing club polos/t-shirts :).
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
