hay i have a 32 with a rb20 and iam thinking about buying a KKR480 its a 480hp turbo for $900 brand new just wondering if anyone has had any experience with this turbo or no anythink about it and would it be to lagie thanks
I'm a proud owner of the KKR480 and have a fair few months under the belt on 15-16psi and its going great. And plenty of power as you can see. I would recommend getting the smaller version though..
Don't worry bout the others let em pay 3000 for the same shit! And use the extra money to mod another part.
And guess what, if it goes bang you can buy another 2 and be cheaper then the others.
G.
https://www.sau.com.au/forums/topic/120635-kkr480-turbo/#findComment-2224151
G.
even the smaller one will be pretty laggy on a RB20...
cohen20; get a HKS GTRS - i have one and its very responsive with good top end. I definitely have no regrets :)
https://www.sau.com.au/forums/topic/120635-kkr480-turbo/#findComment-2224253
G.
hay man thanks and just wondering what mods have you done to get that much power thanks
https://www.sau.com.au/forums/topic/120635-kkr480-turbo/#findComment-2224802
cheap turbo resulting in poor performance
They might make power, any turbo can, but its delivery and lag/response it shocking.
see here, 6 pages of info
http://www.skylinesaustralia.com/forums/in...07715&hl=kkr480
Post in that thread if your question isnt answered mate :)
ps. for the RB20, you cant go post a HKS 2530 if you ask me
https://www.sau.com.au/forums/topic/120635-kkr480-turbo/#findComment-2225018
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
