hey i was wondering if any knows how to light up the skyline sign at the back?
i was thinking of putting a neon tube on the back but dont know how to connect the neon to the back light to make it switch on when i turn the lights.
anyone have another suggestion i would like to hear it thanks you..... by the way im shocking when it comes to electronic, soo i would have no idea where to start when it comes to wiring things.
https://www.sau.com.au/forums/topic/120645-light-up-skyline-sign/
Thats my car in that pic
i used 14 hi bright red LEDs run in series with a resister, then they are tapped into the brake light feed from the rear lights for power
i tried a neon first, wasn't bright enough and didn't fit in there very nicely.;
it was a S1 clear panel, that was sprayed the cars colour, then sanded off the paint from the letters.
these lightup panels were a factory option. look around importers sheds and the like, they might have one lying around. justjap.com, try them
the option from factory looks no where as good as craved's car looks though. The factory option looks like some one went over it with glow in the dark paint.
there are small kits u can buy at jaycar that consist of bars of say 5 LED's that are 12V DC already so its perfect for ur car. they're quite bright i think, look at the MCD rating of LED's to determine their brightness.
ie. those little LEDs u see to indicate stuff are like 15mcds. there are 6000 ones etc. the single ones u will need a small board consisting of a voltage regulator and 2 capacitors or so depending on the voltage of the LED's, most likely they wont be 12..if they are its better to use such a regulator anyway.
i'd probably suggest u use one or two CCFL tubes instead. Theyre really thin and much brighter than neons. The reason being that led's will have regions of brightness etc. ie. the centre of the led, then dim away till the next one and so on. It wont look completely even whereas two CCFL tubes i think would give just the blue glow etc. one just above the writing and one just below. u could be creative and put a little mirror next to the ccfl making all the light go in the middle only.
that sounds easy but do you think you can take pic of it and show me steps by steps of how you did that?
that would be great if you can... if you wanna send it to my email its.... [email protected]
thankz
Here is my "SKYLINE" backlight.
This is how i done it myself :thumbsup:
The "SKYLINE" facia (S1 R33) was first sprayed the same colour as my car. It is advisable to use a few coats of black paint, then spray your colour as required. The black paint should not allow the light to come through.
I then used my Dremal tool to cut out the rear plastic of the facia. Do not attempt to pry the facia apart, you will only end up cracking the plactic.
Then i used a sharp blade, off a Stanly knife (remove the blade from the Stanley knife), to carefully cut off the paint from each letter. (Not as hard/long as i thought it would be :)).
Using a Jaycar "bread board" and my electronic experience, i positioned two hi-intensity LEDs, in series with resistors, in between each letter. This was done to try and minimize the focus of the LEDs. YES, it is damn bright :banana:. It may also help to file the top of the LED's, this will disperse the light better.
It is now ready to be secured into position, I just used some 'Locktite 406' super glue and a small plastic tab at each end. Once fixed, i coated/sealed the rear facia with a good layer of sicaflex, to ensure it is as water resistant as the original.
I had to remove one of the 4 mounting bolts to allow the wires to enter the boot. Using a multimeter i found the wire that lights the night lights and spliced the 12V wires to it. The ground wire was bolted to an existing ground point. Sorry, i forgot what colour the 12V supply wire is :(.
Hope that helps ;)
Good Luck
Alan
  • Thanks 1
Awsome job Al! I have an R32 and have thought about this many a time but couldn't figure out how to get several LED's on the go without wiring each LED individually with thier own resistors but if you can get the common power boards that might just be the trick!
I think I'll only use it as a third brake light though
Edited by ellie
On a 32 it is a lot harder as the letters are imbedded into the bar and the bar is not transparent. You will need to cut out each letter carefully (very hard), then fix a red diffuser behind the letters and seal them, then place the LED's behind that. A lot of work :thumbsup:
I decided to use it as a night light as the LED's are not bright enough during the day, certainly not good enough as a third brake light. Also the police may state that the "flashing" letters (when in traffic and appling brakes numerous times) will be a distraction to other motorists.
Good Luck
PS: Funkymonkey has made the SKYLINE backlight for the his previous R32, maybe he can help you out.
This is how i done it myself :P
Then i used a sharp blade, off a Stanly knife (remove the blade from the Stanley knife), to carefully cut off the paint from each letter. (Not as hard/long as i thought it would be :().
Using a Jaycar "bread board" and my electronic experience, i positioned two hi-intensity LEDs, in series with resistors, in between each letter. This was done to try and minimize the focus of the LEDs. YES, it is damn bright :P. It may also help to file the top of the LED's, this will disperse the light better.
I had to remove one of the 4 mounting bolts to allow the wires to enter the boot. Using a multimeter i found the wire that lights the night lights and spliced the 12V wires to it. The ground wire was bolted to an existing ground point. Sorry, i forgot what colour the 12V supply wire is :D.
Hope that helps ;)
Good Luck
Alan
hey thankz for the picture and everything, do you think you can show me a closer look at the circuit board bcos i wouldnt have a clue on where to solder the LED and where to put the resistor or which resistor to use.
sorry im like a total newbie when it comes to electronic circuit
No probs, will do soon.
The clear "SKYLINE" panel is off a S1. All S1 Skylines have this clear panel between the rear indicators, you then paint it (to match the body colour) and use a fine blade to cut the paint off the lettering.
Can not use a S2 pannel as it is made from black plastic.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
