hi guys,
i just bought my first R34 Skyline and finding it hard to believe that i can only get 300kms per tank when cruising on low boost (6psi).
i understand that they drink alot, but cmon surely i can get more out of this motor? ive recently had a service & tune but ive been told by other rb25det owners that i should be getting more kms.
Can anyone suggest a place that specialises in tuning these motors?? VIC - Melb
cheers
Steve
Fuel consumption that severe could be the O2 sensor if you're doing lots of city driving, if you're not it may be pointing at something a bit more drastic.
I'm getting ~330kms from full to empty light first coming on and I've got ~180rwkw and drive it quite spirited most of the time.
If your car is stock standard I'd expect to see at least 450km or more when the empty light first comes on.
Sorry don't personally know of anyone I can recommend down there
Last time I think I read that Nissan want $400+ for a o2 sensor... Repco replacement for the Ford is around $80 :laugh:
I think I might give that a go too... although, when I plugged in the consult gear, the o2 wasn't reading anything abnormal???
EL falcon for around $82 from Repco.
Ive read numerous times that an O2sensor is good for only 40000kms, after that replace it.
My Stagea had shitehouse fuel economy, had 80000kms on it when I got it, and got around 230kms per tank (65litres), now after having the O2 sensor replaced I get 430kms per tank (around 60 litres).
I changed my O2 sensor.. TWICE, and it makes no difference. I checked both new plugs with some consult software, and they were operating correctly.
I've read hundreds of posts, and I don't recall anyone every saying that it fixed their fuel problems (apart from above) or gave anything more than 20km extra to the tank. =-[
It's not a magic fix, it seems.
I'm now searching for any kind of results from tuning AFR's with a SAFC.
Edited by RANDY
Yeah my O2 sensor doesn't affect my economy as I'm mainly doing more than 2500rpm...so the ECU is controlling fuel delivery. My O2 sensor is also a bit screwed with the ceramic/platinum tip snapped and rolling around in the end of the sensor (gives it really slow response)
whilst I might get way more kms then before, I should state that the Stag has spent a few hours on the dyno with 2 tuning stages, first tuning a SAFC (fuel went from ~230 to ~360), and now with the sitc, if I mother it a bit I'll be in the low 400's as stated, if tromped a lot on boost then high 300's (all before fuel light comes on).
replacing the O2 sensor, I feel, worked in my case. as far as getting GTR ones, Im not sure, Im poor and only have the lowly rb25.
ill have a look at the o2 sensor.
I have a 3.5" exhaust and ive also got a power fc that isnt installed yet. Will it help getting it installed????
The Power fc doesnt have a hand controller, so should i buy one or get a mechanic to tune it. are the hand controllers easy to use?
im also getting a back fire in between gear changes, could this be a possible sign for the o2 sensor??
cheers
Edited by Tough R34
i get about 12l/100km's... you can't really say i get such and such for a whole tank, because the tank is 65, but if you fill up when the fuel light comes on, you'll get like 45 litres in.
i've been doing 15litre fills the last 5-6 times, and getting around 120-130km's from that (when fuel light comes on) which works about to be about 12l/100km's...
you get a bit more accurate idea if you work out the litres/100km as opposed to a "tank" - check how many litres you actually get in the car, when the low fuel light comes on... you're not going to get 60-65 litres in that's for sure
Tough.
Yeah that was me.
I like your wheels. They go well with our colour.
If you haven't tuned your PowerFC, you will get some fairly good returns from a good tuning session.
Backfiring between gearchanges says much to much fuel is being supplied.
Talk to Ice or Racepace or any other reputable tuner and get it tuned.
You'll love it.
I get about 320klms out of 50 litres with normal driving.
If I stick the boot in, I can almost watch the needle going down.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
