  • Replies 291
Posted Images
lol its ok to be confident but use your brains... everyone keeps crapping on in the most arogant way and it makes me laugh... im going to head down to fed square tonight with my cameras just to capture the look of heart shattering despair as every aussie in the crowd that kept boasting that the socceroos are going to smash italy realise it aint going to happen
Fianlly someone see's the same light as i do, One world cup campaign or championship doesnt make a great team, look what happened to Sengal where the f**k are they now? What happened to Greece after they won Euro 2004? Great teams will keep winning and only time will show this.
*huges my 42" High Def Plasma and My Full Body Massage Chair for tonights game*
Edited by SLYSX
you 2 aren't the only ones that think this way...
i had hoped that it never came to italy v aus, because i'd be conflicted...but the way the media acts, turns me off supporting australia all that much...
when its against italy that is...
Guest IH8VEE8S
oh yeah?
*hugs my 62" HD tv* :D
who needs to go down to fed square when you've got 12 soccer FREAKS at my house with a tv that big..... :sorcerer:
already made bets on this game with 3 mates, $20 with each, italy 2 australia 0
Edited by IH8VEE8S
oh...here we go
forza azzuri.
well played australia to make it that far.
italy played with 10 men for the second half, and australia failed to take advantage. thats soccer.
the commentator said "australia deserved to go through to the final 8, but instead it's italy"
sorry, but they didnt deserve to go through. if you win, you go through and thats that. its like saying qualifying for the world cup means they deserve to win it.
i expect to be flamed, but bring it on.
like i said, if that was italy Vs X team, i would be going spastic right now, but ive stayed calm because i was a lot more in the middle than if it was any other team....but at the end of the day, italy won, and they deserve to go through.
if australia had gotten a penalty at the end like that, the fans would be going spastic, and not a word about the referee would be said.
it might hurt, but thats how it is.
Forza Azzuri!
not relevant !! ;p I dont care but f$% it was funny at my work when all the half pissed punters got hella angry at every wog in the world all of a sudden
italy had 10 men and aus still couldnt close it out so bl all round i guess
http://img84.imageshack.us/my.php?image=10...v1jvdgua4xn.gif
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
