I've been told that QFM pads are good for normal street use, so i'm getting a set of these as they are relatively cheap.
I have a track day coming up though, and I thought of getting some RB74's for the fronts. I can't afford DS2500's at the moment so these will have to do. Will having RB74's on the front and QFM on the rears cause any problems? I've heard on the grape vine that it may cause some understeer. Is this true?
___________________________
I've been told that bendix ultimate are very harsh on the rotors, and give a ridiculous amount of dust. I was recommended the QFM's instead. Supposedly they were co-designed with one of the guys from Racebrakes. Does anyone know whether they are good for spirited street driving?
https://www.sau.com.au/forums/topic/122075-mis-matched-pads-frontrear/
Yeah a Friend of mine had the qfm pads on his modified WRX and we were at a track day they seemed to go really well. He was happy.
I think those guys can make a number of different compounds for their pads depending on the application.
My friend's were just the standard sort of pad they offer.
They are cheap too.
let us know how you go... no great loss if they are no good I guess.
Um, unless you are getting pineappled for the price of the DS2500's, they should only be $80 more than the RB74's or thereabouts. How much are you paying?
You need to make sure that the friction coefficients of the front pads matched that of the rear pads.
Understeer? No. What an imbalance can do is make either the front or rear brakes lock prematurely & degrade your overall braking performance.
Dusty, yes. Harsh, no. (Compared to what?)
If racebrakes recommend them they are probably pretty good.
Well I must be getting ripped off for the DS2500's then.. $245 for a front pair.
I can get the RB74's for $120!! Screw paying twice the price for something that's surely not going to go twice the amount of time before overheating! :P
hmmm.. ok then... i might have to get RB74's for the back as well.. I might buy some and see how I go at the beginning of the day... If it's causing problems i'll swap them over.
Well I've heard a few opinions that said that they are harsh for what they are. ie. not that good when it comes to track situations (heat wise), but still just as harsh on the rotors as a more high performace pad.
You are getting the RB74's at a really good price...
You don't need RB74's for the back. Racebrakes usually just tell you to use a Bendix Ultimate pad or similar as the back brakes don't really do much & you don't need a pad that deals with high temps. If the friction coefficients of what you have matches the RB74's I would be very tempted to leave them alone.
More important than pads is good fluid. So get some Motul RBF600 or equivalent.
Yeah I'm getting the RB74's through BDA http://www.brakedistributors.com.au/
The reason they're so cheap is I'm able to get them for trade, which is handy!
Yeah I've heard that before about the fluid - I had Motul 5.1 in there for the last track day and it was good, although I had crap pads on there so the little fade that I had may have just been because of them. Do you know if the RBF600 is much more expensive than the 5.1?
-- Edit: ignore that last question... I've just found it's just under twice the price http://www.uniqueautosports.com.au/priceli...elist_motul.htm
Fair enough.. I might give it a go this time around! :P
_________________________________
Anyway thanks heaps for the info DJR - Very helpful!
  • 2 months later...
Im interested in trying some DS2500s on the front of my car. I have used RB74 fronts with comp 2 rears, but more recently Comp 9 fronts with the Comp 2 rears.
Have always been happy with them, but ppl keeping touching themsleves over the DS2500s so want to give them a try. Only woudl like to hear from ppl that have used them and hear what rear pad they think works well.
I have 324mm front rotors on my car, and have found the Comp 9 - 2 mix to work really well....so want to be sure the $500 odd im about to spend will be markedly better and not cause bias issues.
What are these DS2500's (sorry moving out from underneath my rock tonight)!
I have just been pricing up EBC redstuff for my 32 GTR at around $250 per end? Are these DS2500'S any better?
The car is just a weekend car (if that) and I am after a track suitable pad.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
