Are you sure??
There was a thread that showed a gcg hi-flow making 260ishrwkw and putting on a vg30 rear housing and making 280rwkw (not exact figures).
So wouldn't this suggest a vg30 is bigger? I cud be way off here but i thought thats what i read.
hey ppls.
I'm making 250rwkw (with more than 240 for about 2000rpm) on the GCG high flow with poncams (260 x 9.15)
Flapped valve was loose so boost response was ordinary. Fixed flapper valve, boost response is now awesome! I can make full boost in 3rd at 3000rpm. Well, 1 bar, and I run 0.9 bar to make 250.
Once the new clutch goes in, I'll be taking it back to the dyno and having it fine tuned again to try to pick that number up a bit.
I've got all supporting fuel mods and blah blah blah.
BASS OUT
GCG state on their website that they don't do group buys.
Tell me about it, it took me a year to organise. Finally I had to arrange it via Jamex (a GCG, Whiteline and Bilstein reseller) and they only did it because of the good response from the suspension Group Buy.
:whistling: cheers :P
I've got 255rwkw at only 0.9 bar so 260 not out of the question. I have the GCG highflow btw.
I've run 12.7's
Car is an auto.
$500 for a second hand R34 turbo.
mate ..if onli u told me i would have bought that turbo!!!....blew my MTQ hi flowed one :yes:
how do the MTQ hi flowed ones rate anyways?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
