is the intercoolers made in japan????? or are they designed in japan?????
I will answer this for you.
They are made in Taiwan, and use the same design intercoolers as those that have been coming out of Taiwan for over a year
  • Replies 52
r u sure that they're the same design as the cheapy copies?
i know they're made in taiwan but i tought they were designed and tested by greddy but just manufactured overseas.
They are. I can't comment on teh design but people should ask themself do you think they would risk there reputation over a cheaper alternative :P
And update on deleivary i called and i've been asured they will be ready for pick up on tuesday.
As i said i can't 100% say the design is different i havn't compared the tow, but just becuase they look the same doesnt' mean they are. For starters the piping is different and the joiners for the piping, so thats part of teh kit making it "different" not exactly the same. A company like Trust/Greddy arn't exactly going to walk in to a company making these cheapies and wack a badge on them. Yes they are not Japanese made hence to keep the costs down, but on that note they are made to Trust/Greddy specs (as they woudlnt' want to risk there name over a cheaper alternative) i wouldn't confidently say that a company like Trust/Greddy would nto have wacked there badge on some no name brand cooler and hopped for the best, they would of been designed with the intent to target a market dominated by cheaper no frills coolers. So with that in mind they would of looked at manifacturing them abroad (out of Japan) and thats why they are only rated up to 270-300kw. They are perfect for what the are, it all comes down to preference, save a few $100 on a no name brand, or pay the bit extra for a trusted brand. It's like that with everything.
Nav2k you might find more info at the website or even email them.
Regards
Michael
hey "Michael_1882"
im interested in the kit..
but short on cash at the moment..
what is traded in with the stock cooler?
the side mount with piping etc.. wat do u have 2 hand over..
and when will these be comin back in a group buy?
cheers mate..
thanks michael_1882.
thats what i thought too..theyre designed by greddy but made overseas but the other guy said that wasn't the case..so i wanted confirmation on that.
i know the piping is exactly the same as the other models.
Intercoolers have ARRIVED!!!!!!!!!
Hey guys, well the intercoolers are now it, those who were picking them up can collect them from today onwards, those who require postage once full payment is made then the coolers will be send and those who required postage and have already paid in full, your coolers will be sent tomorrow.
Pm’s replied to.
And people still interested I’ve been told due to popular demand from both this forum and another there will be an order placed in asap for another round, so if you missed out this time and are interested PM me.
Regards,
Michael
Theres "1" spare R33 kit, and plenty of silvia kits, anyboyd interested pm me.... as mentioned might run another group buy in the future, if there is still enough interest.
Edited by Michael_1882
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
