Looking at getting rid of my first car, this 1980 Toyota Celica - it seems a shame to just have the thing picked up and taken away for scrap metal, so does anyone have any suggestions as to what to do with this car (I don't really want to spend money on advertising it for sale if I'm just gonna make $50 on it).
I'd like to get something for it, but I'm more interested in it going to a good home and being fixed up if it is worth it (it's down a cylinder and has some minor rust after sitting on the side of my house, neglected, since the end of last year). It does have a fuel catalyst, so it can run on unleaded or premium (preferably the latter).
Is anyone interested in taking this off my hands? (located on the Sunshine Coast)
(Mods feel free to move this thread if you feel it should be elsewhere - I was using this thread in an attempt to get suggestions, not really for the purposes of selling it.)
https://www.sau.com.au/forums/topic/123483-getting-rid-of-old-car/
It ran extremely well for a '80 model car until about mid-year last year, then it started stalling at lights. I had a compression test done, and it showed that one of the cylinders was running extremely low.
Other than that, the gearbox was fine (it is an auto by the way), electrically it was fine, the interior was almost perfect, and it only had minor rust. It now has about 7 months more rust, but that's about it.
I did actually get my hands on another '80 Celica with the intention of doing an engine swap (which is all that it needed), but I subsequently found out that the second Celica had been used for paddock-bashing in it's later years, and the results of a compression test on that car weren't that much better, so I got rid of the other car.
hrm, i'd be interested in coming and having a look at it at some stage.... pm me what sort of figure you are after, as i need something to drive to work... i'm getting too paranoid to leave the skyline out and about any more...
  • 3 weeks later...
  • 3 months later...
Last call - I'll be having this car picked up and taken to the wreckers on Wednesday (8/11) if no one wants it. I'm moving house this week and the car can't come with me, so let me know if you're interested in saving this poor old Celica from death!
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
