I just had the 100,000km service which included having the trans fluid changed. Since then it seemed as if it was shifting slower and that sometimes the revs would flair between gears.
Then tonight under hard acceleration when changing from 2nd to 3dr it just let go, tacko hit 7,500 rpm and the power was not getting to the wheels.
Its fine changing between 1st and 2nd when I have the shift leaver held in 2nd and if I hold it to about 4,000rpm and then move it to drive with the throttle closed it changes into 3rd ok. The change into 4th seems ok as well.
The trans fluid smells like burnt rubber now.
I know MV in Adelaide are the experts on these but can anyone recommend someone good in Melbourne who can replace the bands and clutches with heavy duty items and fit a shift kit?
Edited by Burns
https://www.sau.com.au/forums/topic/123609-my-auto-is-stufed/
Check and make sure there are no leaks of A/T fluid. Check oil level.
It willcost BIG BUCKS to fix. I just paid $4k on a Subaru. Do any of the Skyline boxes fit?
For about $12 get a bottle of Nulon for A/T. It may keep you going till you get it fixed.
oh the sliptronic auto... time for a manual conversion.
My auto did the same thing once, after a night of going crazy off the lights after i first got the car. Didnt want to play the game. i drove it home.... verge of tears... woke up the next morning and drove it to work - it was fine! tight as a drum. was like the damn thing just healed.
May have just been heat?
Is yours still playing up?
My auto has its good days and bad days.
Some days, it shifts soo quick i get a slight chirp on gear changes.
Some days, it shifts so slow on gear changes that I get have this thing where if i change from 2->d, the revs jump about 500rpm while keeping the same gear, then i hit the rev limiter while in D, then it changes.
On another note, its my 2->3 gear changes which are worst. Ive gotten about 1-1.5 full seconds of slip between changes....then the next morning its just been fine?
As above, check ATF
overheated fluid, incorrect fluid level (too much or too little) are 2 main things that will affect their performace. getting the fluid changed can sometimes cerate problems with the auto trans fluid filter being clogged, then the clean fluid loosens all these particles. take it to an auto trans specialist and get them to service it properly, not just replace fluid.
Nope it’s stuffed not just a bit of slippage or heat caused. The fluid level is spot on and I have a big trans cooler fitted. I took it for a little drive just before and it changes out of 2nd but not into 3rd. It just releases 2nd then free revs not changing into 3rd. When I slow down or change it back using the stick it goes back down into 2nd.
I have 1st, 2nd then neutral revv revv and go no where.
When I had it serviced they also fitted an adjustable cam gear, spit fire coils and gave it a tune so it’s putting out about as much as you can with a stock turbo.
I think the flex band or clutches between 2nd and 3rd have gone.
So am I the first to break a Stagea auto?
I will give Keas a call tomorrow and see what they think.
Edited by Burns
sounds like the bands need tightening, used to be the same on my old vl turbo auto, not fun when it slips like shit to the revlimiter everytime u put ya foot down or when it kicks down :P
I find that my auto changes are a bit sloppy when it is cold. Once I've been driving for a while, and the trans warms up, it seems to tighten up and changes become a bit sharper.
Sometimes it gets confused when I accelerate quickly out of an intersection and throttle off before it changes, it seems to hang for a bit and then change.
Auto's are all black magic, smoke and mirrors to me. At least I can visualise what is going on in a manual box when I change gear.
After I fitted my FMIC I found, what seemed to be, a loss of power which I thought was either lag from the new piping (yeah right) or that my boost control valve was playing up. After some inspection I found the the boost level was actually not changing when this was happening. This usually occured under semi-light throttle with about 0.2 bar boost.
Then I started noticing that it was taking a looooooooooonnnnnngggg time to change gears when I had the foot up it. On sunday I attempted to pull away from an intersection & found that I had barely any drive, I backed off the throttle & reapplied it to find it was there again. Today after giving it a squirt it SLAMMED into the next gear after holding between the gears. Not a whole lot of fun really. Still, it does give me more reason to do the manual conversion now :D
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
