Yeah that and the plastic bit that goes around it, remember it broke when we *cough* you took it out :P nah I reckon it was broken before you even touched it eh, I didnt hear a crack or snap, it just fell apart in your hands.
Still RIP Green Beast that idled for 3hours when you helped me do the speaker install ;)
do you want to get rid of the grille, or keeping it for good luck?
Mate that question has been plaging me for DAYS. i dunno. The next one will be a 34 front, so i wont NEED it, but it might be good on my wall, more as a reminder than anything else.
damn, i was gonna offer you something. I'm getting bored of my grill not having any detail except mesh. probably better off keeping it for future reference to remind ones self of the dangers of speeding ;)
so Rob, whats it like being hit in the face with an air bag?
It must be a very plush airbag in the Stagea, as evidenced by the lack of injuries. Airbags FTW! I've got 4 of em in my Stagea, but I dont plan on trying them out any time soon.
There was one in Perth that hit a bus and caught fire while the driver had his foot stuck.
i know the one in QLD was involving a bus was a forum member called mad wagon would have to be close to 2 years ago now
That's right, IIRC he said he would probably buy another Stagea, but we've hardly heard from him since...
after 3months of ownership, it's just about to where i want it.
full bodykit, exhaust, bilstein coilovers, hks filter, and 17x9.5 sparco wheels off my drift car until i can be a$$ed putting 19's on it.
car is for sale to fund house purchase. does not include white 17's, but can put 18, 19 or 20" rims with new tyres on for below wholesale cost.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
