Yes they fit, have fitted a dozen, no problems, only differnce is 6mm bolt on top of pump doesnt fit.
Hey guys,
my 100k service is coming up and i have heard that vl turbo water pumps are a direct bolt on for the r33?
is it worth getting one to save a few $$ or should i just fork out more for the rb25det replacement pump?
cheers
yes use one, will cost you about $90. bolt does not matter.
So a VL turbo water pump will be suitable for me to use when i get the 100k service done?
Is there a particular brand i should use or just nissan oem product?
will the 6mm on top not fitting matter?
cheers
I wouldnt risk it. If it leaks you have to strip it all down again. Original is only about $130-$150 from Nissan I believe.
My pump felt fine so I didn't replace it. Thought there was more chance of a new one going dodgy or getting something wrong on the install.
If there was any play or sign of weeping I would have replaced it. Also, if I was paying for labour I probably would - but with the genuine item
I used the rb25det one on my rb30det and could not fit that one bolt - it ended up leaking where the bolt is supposed to be. Lasted 5000ks
I got a rb30 one on and have not had any problems since. 55 thousand k's later
And is the warranty valid for labour? What will they say if you installed it yourself and it isn't the intended part for the job?
A repco Rb30 one will be fine provided it goes on an Rb30 bottom end!!
Point is why would you try and save $70-$80 getting one that misses out on one bolt and has the posiblity of leaking.
I.e a good 4 hrs down the drain and then you have to buy the correct piece anyway.
The Rb30 unit is not recommended for the Rb25. I went through the same process. I know my series 1 has a one bolt hole that doesn't line up which I think most people have found.
In my experience repco/autobarn one's tend to rip up the front seal after a year, go nissan...
Agreed. I used the RB25 pump on the RB30DET conversion and it leaked for me. I got a cheapo $25 pump from repco and its been running good ever since. Should have done this in the first place!!!
Get a price on the real item. If it is <$100 more than the one with the incorrect bolt hole then why bother talking about it.
There is more of a chance of it leaking with the bolt missing.
Sure, it may be ok. But is it really worth the risk?
wow $25 pump.. shiet.. The aftermarket item I bought was $83, there were slightly cheaper items but didn't come with gaskets and lacked warranty and a quality finish.
There's also a few different aftermarket variants.
I've seen one that has 'one' elongated hole that has the provision for the rb25det.
Yeah, if you can get an aftermarket pump with the elongated hole it will suit both the RB25 and RB30.
Otherwise you will have to leave a bolt out, if you try and interchange them.
Something you don't really want to do.
I think it's been shown by reputable people that the flow rates from the N1 pump aren't optimal for street use.
I think Nissan even sell one for about $130 trade that has the elongated hole..
Sometimes Nissan don't really know what's going on though
Edited by benl1981
my n1 water pump runs perfect and never gets hot on my rb26 when doin low rpm in traffic and thats after 1200km of driving, though no flogging yet but i know they are meant for high rpm which is why i got it, so i cant see any dramas with them, but only time will tell :(
Brother, I am a mechanic by trade and run my own business. I wouldnt fit the aftermarket pump if i thought it might fail or leak as it would cost me money to replace it. as earlier posted, have fitted a dozen RB30 aftermarket pumps on RB25, Rb26 & RB20. Some of these engines making upward of 280rwkw. Pumps have been on cars for over 12 months in some cases and i havent had one leak. Im all for running quality parts, genuine if necessary as i never use aftermarket seals, but when you find a good quality aftermarket part that can save you $60, ill use it. That $60 will pay for drive belts etc. The brand of pump i use is a Truflow and is supplied by Auto1. Good luck with it. it is only a simple water pump replacement at the end of the day. I sure all will be O.K. which ever way you go.
my n1 water pump runs perfect and never gets hot on my rb26 when doin low rpm in traffic and thats after 1200km of driving, though no flogging yet but i know they are meant for high rpm which is why i got it, so i cant see any dramas with them, but only time will tell :dry:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
