well i got done for my:
exhaust - i wanted to get a new quieter tip anyway
pod - will getting a pod enclosure pass me?
tyres - sorted
ground clearance - just my sideskirts are low, i could just take them off
and i got this other one that says "engine modifications to comply with standards".
i dont have any engine modifications other than the ones he mentioned.. and even if i did, can he defect me on something he cant see himself?
EDIT:
so far ive sorted:
- ride height
- airbox
NEEDED:
- standard muffler
https://www.sau.com.au/forums/topic/124545-got-defected/
yeah i got screwed.
ive got to get a blue slip for this one.
the front and back are fine.. its just the sides, they sit around 60mm off the ground.
i dont have the chromies anymore, its sitting on stockies.
you shouldnt need an actuall blue slip..
just someone that does them..
all they have to do is sign the bottom of the defect and done!
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2300622
mate i hate to say it but that car with a loud exhaust, bright yellow paint job, body kit with our without the chromies is going to attract the friendly eye of the boys in blue. especially if you are still on Ps. (think you are?).
it is harsh, but perhaps think about a more sedate colour/body kit choice next time! lol
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2300769
good to know! thanks for that.
Far out Joe thats suxs you getting defected and just got it back on the road :whistling:
Were did they get you ?????
they got me literally 30secs away from my house.. they were following me for a bit. stupid undercovers dont think i can pick them out :pwned:
haha yeah but i like my colour :)
my aim is to get my car streetable anyway, i just need tyres which will be sorted anyway, my exhaust which i wanted to quieten, my sideskirts make the car low so i could just take them off.... im not sure about wether or not i can use a heat sheild for the pod or do i have to use a standard airbox?
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2300936
Your best bet would probably be to borrow a stok box to get it cleared, and then put the Pod box on after that to decrease defectability
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2300948
God I hate it when you are literally down the road from your house and they get you but its the usual story sorry to hear hope you get it off soon :whistling:
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2300963
the front bar was on.
im stull not too sure as they've ticked the "exhaust noise/emissions square".
what sucks is i cant drive it as theyve given me a red sticker! bastards.
What they give you different color stickers here????
In adelaide its only one color yellow so it would match with your car Joe hehe :) shouldnt laugh sorry
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2302222
Yeah N1_R33_GTR.
I forget what they all mean totally but I think its like
?? = Vehicle must only be driven to workshop and back to clear defects.
Yellow = Driveable - defects must be cleared in ?? days.
Red = Can't drive vehicle. Must be towed.
I think it's something like that. Ive been lucky enough to never cop a defect yet.
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2302413
Yeah N1_R33_GTR.
Far out I hell dont want one here then :D
https://www.sau.com.au/forums/topic/124545-got-defected/#findComment-2302475
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
