The subject for email notifications no longer reflects the name of the thread that it's notifying about. Is this by design?
Also, in the thread list view, rolling over the subject used to display a tool tip with a preview of the text in the post. That hasnt worked for a while either.
Just though I'd let you guys know.. Cheers! :D
https://www.sau.com.au/forums/topic/124703-email-notification-subject/
  • Replies 89
I have to say that the old style way of thread notification was much better as it allowed for the emails to be sorted by thread name, now they are all just sorted as one and you have to go through each one.
Rather than starting a new thread...
I haven't been getting email notifications for months (since the upgrade a few months ago I think) I've checked every setting and had Merli go through them with me but still no emails came.
It might have something to do with me changing my registered email address for here just a few days before the upgrade.
Anyway, now I seem to be getting emails for every single new thread made in For sale parts for some bizarre reason. As you can imagine that's a lot of spam.
thanks.
adam.
thanks.
adam.
I used to get 250 emails a day from reply notifications from wh0retown! lol
and yes having to sort it was easy enough, but not now :D
Ahh thanks for that.
I now see that in the options button up the top of a thread there is no option to subscribe to the thread only, it subscribes to the whole forum. You actually have to post and tick the box to be subscribed to a thread.
If you click on "track this topic" it subscribes you to just that topic.
should be at the top of the options listing.
Damone
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
