Fate has forced my hand! The R32 just blew its turbo so R33 wheel studs need to be fixed so I can drive it while the R32 gets its upgrades done!
Does anyone have any useful advice for me on how to do this?? Or does anyone want to come and help me do it on Saturday afternoon? Rewards of course will be offered for the helpers :D Thanks guys
https://www.sau.com.au/forums/topic/125048-stripped-wheel-studs-on-my-r33/
1. Take wheel off
2. Take caliper off disc
3. take disc off
4. get big hammer
5. belt old stud out
6. slide new stud in from behind
7. use old stripped stud as a punch to push new stud in (or alternatively get a rattle gun and do up a wheel nut onto the new stud to pull it through)
8. put disc back on
9. put caliper back on disc
10. put wheel back on
11. ????
12. Profit
Where do I buy the new studs from??
Jason there is alcoholic rewards if you come help me :D
try repco they will normally have a range of wheel studs...
i got mine from option1garage over @ hamilton (although i have slightly longer ones 70mm i think)
make sure you get ones with the correct spline, as you'll have a mission of a time bashing them in, or drilling bigger holes etc...
the rattle gun method Azzura mentioned is good, just make sure you dont over tighten and end up ruining your thread as a fair bit of heat is generated. a rubber mallet is also handy - dont know when i used it but i know i used it heaps. after you've replaced the studs remember to periodically tighten up your bolt nuts as they settle in.
not a big job, just time consuming ;)
good luck
good luck
Yeah don't try to put a front stud in the rear hub, and waste two hours of your time before you realise that they are actually different!!! Like I did at the track day!! :D
Studs are only about $5 each... Once you know how its pretty easy - like anything I guess.
You dont HAVE to use a rattle gun, but it makes it much easier.. You will have to pack the wheels stud up with washers or a big nut so that you can wind the nut onto the stud without running out of thread on the nut. I hope that makes sense?
i'm happy to help out Andy.
I got my wheel stud from Nissan, as they are the same as R32 GTR ones.
was cheap as chips... think it was like $7 or something
don't know if they'd have R33 ones though, or if they're the same etc (though one would assume they would be?)
Oh dears! I was wondering what you were gonna do! I felt so bad for ya too, you were having an awesome run!
Hey Andy,
You got my number, gimmie a call if you need a hand. I am but 5 mins from your house.
Thanks mate ;)
I should have watched you fix that!! By the way....Watching your car on the track got my mouth watering, gave me a preview of my engines future :)
Thanks mate! ill give you a call later in the week??
I should have watched you fix that!! By the way....Watching your car on the track got my mouth watering, gave me a preview of my engines future :D
Hehe yeah, if only you were psychic and knew you were going to need to know how to do it! ;)
I can promise that you wont be disappointed with the turbo! :)
Hehe yeah, if only you were psychic and knew you were going to need to know how to do it! :D
I can promise that you wont be disappointed with the turbo! ;)
I knew at the time that it needed doing...I just didnt know that is what you were up too!!!!
we can have "comparisons" at EC in October Woooooot
if you need to know details of the studs that are required check out the www.niceproducts.com.au website - all the info you need is there
I am having mine replaced, but the biggest problem has been finding wheel nuts to suit my mags ..
A workshop told me it's only a 20 minute job to preplace all studs to both rear wheels .. sounds like the easy option to me
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
