  • Replies 178
arrrrrrrghhhhhhhhhhhhh this is driving me nuts... i cant wait....****smashes head on keyboard**** then goes and vacuums car!! :laugh::):O
*hands you a valium*
update on my covers:
for those that remember, i bought a set just before the group buy and have now had them on my car for about a month..
they have all ironed out their creases and are perfect still..
great quality and look absolutely stunning
i've had about 15 people comment and say its the best interior they've seen on an R32.. and they all thought it was leather, even after touching and sitting in it!!
just some more to keep you occupied while waiting :D
i have just been speaking to Ultimate, the covers are half done, they are hoping to finish all by 1st september and dispatch 2nd September..
Awesome, sounds good to me - lets hope they can get them dispatched by the 1st of Sept, as the 2nd is a Saturday, but all in all we should have them by the 6/7th of September.
Sounds good to me, they had alot of covers to make, glad they got them done quickly. Cheers for the update JetDat, talk soon.
I can't wait to see how it goes for you guys. Hope you don't mind me posting in your confirm thread, considering the gb is done.
I just wnated to see how it looked, how hard it was to install etc.
I figure, even if i have to pay a bit more, at least i'll know if it's good or shit.
*drools*
haha I can pick mine up even on a Saturday!
Yay.
1-2 September for me :(
If they send it out on Saturday, I don't think they will be sent out by AustPost until Monday - that was my point.
Aust post does pick ups from the boxes on sundays apparently.
Also interstate delivery with austpost is 1-6 days generally.
You'd hope that you'd be getting a courier for 30$!!!
I use them all the time at my work, and an insterstate box only costs around $10
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
