  • Replies 178
Are you guys dieing waiting?
I'm just waiting for some of you guys to get it so I can have a look, then if they're good, i'm ordering some too.
sighs..... that means i won'tbe getting any for like 2-3 months.
You bet, I'm going overseas for a month on 1st September, so I may not get them for some time yet :rofl:
Might have to give them a call to see if I can get them a day or two early (if they're ready)
Edited by CNR33
yeah its a bit like that isnt it..
we handed over almost 20 grand...kinda worrying but these people are very nice and i know the seat covers are high quality...
personally i dont want them to rush and compromise quality...
Now that the delivery is getting closer, what the final word on installing these. I'm pretty sure everyone will be doing the seats themselves, but what about the door trims? Are we all gonna have a go at installing these too? If not, anyone know someone who can install the door trim pieces into and R34 GT-T?
Cheers.
That's a good idea ozan. E.g. have you guys thought of techniques of how to get a good fit?
Like you know how the seats have those little adjuster knobs on the side, how do you take them off? then I'd imagine you'd have to make a small hole in the cover to put the knob back on the outside etc.
Also, found an auto trimmer here in Brisbane. They aparently do all of brisbane bmw and porsche and have worked on imports before.
Anyway I'm gonna get them out, let you all know what they are like.
Website: http://www.leebros.com.au/
Edited by OzanMakinaci
wtf? Do it yourself .... you do not have to take off the old covers - you just slip the new covers over your existing seats .... how hard can it be?
Yeah you'll find out 3-6 months down they will start to slide around and not fit properly, get it done properly the first time have it nearly as good as factory.
And yes I would rather pay to get it done properly, need to get door trims done too.
man!!!!!!! do it urself.... farrrk :)
It's a lot better when you take the old cloth off and glue the leather ones on.
that sounds like a good idea. anyone obtained quotes to get this done professionally?
IMO, it's not worth it.
The idea of these seat covers being that the price is moderately less than a proper leather retrim.
If you've gone for the premium package - 630 + 3-400 to install it, then that's 1k. I know it's still less than a leather retrim, but at the end of the day, they'll never be as good as a leather retrim for 2 main reasons:
1. they're plastic.
2. leather retrims sew pockets into the back of the leather, and they refit the metal rods that are in the stock seat covers. They use hog rings all over the seats and velcro such that it actually hugs the contours of the seats.
have you noticed in the pics that these covers are just limp?
Manwhore, i suppose you might be able to glue it, but it'll mean that the covers can never be changed otherwise the foam will be damaged.
I have friends involved in retrimming and they suggested i just do it myself as the outcome will be the same for those reasons mentioned above.
Oh man, if you wanted a professionally installed leather interior, then you should have gone to a trimmer, these are seat covers and are therefore meant to be slipped over the origional seat trims for a good fit, unless you dont take care of them or put them on properly the first time then you wont have any problems with them.
As for door trims, they are easy as to install, man if someone wants me to install them in sydney then let me know, i custom cut, glued and made my red italian leather door trims and they look awesome! just got a few pointers from a mate that did his interior in vynal and i was off.. no problems at all....
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
