Hi all, i want to fit a set of these 'alloy subframe bushes' to my R33. my question is - how effective will these be if the factory bushes are really worn? will they still lock the subframe from any movement?
thanks in advance!
Sam.
https://www.sau.com.au/forums/topic/125577-alloy-subframe-collars/
thanks in advance!
Sam.
Do you drive this car on the road Sam?
Well, you won't be after you fit alloy bushes
:thumbsup: cheers :wacko:
its pretty harsh on the road as is. i feel every little uneven-ness in the road with my coilovers. i dont really want to go to all the effort of completely replacing the factory bushes, and ive heard mixed opinions on pineapples, with some people reporting they dont make a lot of difference? ive heard the same about alloy bushes, apparently they are effective but cause increased NVH, although ive read a few people say they arent that bad?? any other opinions?
think about it. U are now connecting the rear suspension via metal to the chassis. If u think the aftermarket coilovers u have now are harsh, add more NVH on top.
Only solution is either to replace the std silicone filled mounts, fit Noltec subframe mounts, or fit poly pinapples. Noltec ones add a little bit on NVH due to the stiffer urethane used, but it is a way better solution than alloy spacer bushes.
Speak to Shaun, as hes fitted the Noltec ones to Freebaggins r33.
Not the same car but I fitted Urethane ones to my HR31 rear subframe and fark me it made the car way harsher. If you had some fair decent rates in your coilovers and metal bushes in the subframe I wouldnt want to be in the car for more than 30mins of daily driving.
I run metal ones in my r32 with all the rear suspension bushes in poly and 5kg/mm rear springs.
It's fine, there is still some rubber between the top collar and the floor
and the more solid feel of the back end was worth any minor increase in NVH in my opinion. If i had a mechanical diff it may be a different story though...
hmm, many different opinions on this topic.. same goes for all the topics i have searched through. it seems most people who have fitted alloy mounts claim that they are not that bad. im not sure what to do. it seems my stock bushes are very worn. im stuck in a situation at the moment where i cant easily get my car to a workshop for the duration it takes for a full replacement. im leaning more towards the alloy ones for the fact that there is no more movement in the frame, and i can install them myself.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
