Hey Fellow Skyliners
My Brembo's are in need to be painted and I was wondering what is the best method.
1. Painting them myself, using VHT brake paint.
2. Sending them away to be painted professionally. Recommendations who?
Also, Would anyone know where to find the "BREMBO" stickers?
Thankyou in advanced
Intune
https://www.sau.com.au/forums/topic/126022-painting-r33-brembos/
Give then a good clean, mask the area off with newspaper and way you go. I think with brembos it should be stamped on the caliper just scrap of the paint with a knife. Use a paint pen to high light BREMBO.
Don't waste money on VHT. Looks crap after a few heat cycles on the track on my racecar, although that was a nice job on those above.
Go with the Duplicolor Metalcast. Looks too sweet. I've used it on the cam and front cover of the RB26 and the Sumitotmo calipers on one of my GTSt's and it is wonderful.
Thankyou for your replies.
JK
Your mate Brendan has done an AWESOME job and look great. Still I am unsure sure how he done the lettering "BREMBO".
Would be OK if I email him?
Cheers
intune
GTRgeoff
Would I find that paint at repco or somewhere like that?
Cheers
intune
No need to be formal here. Geoff is just fine :)
I get mine from Supercheap. Used a wire wheel on the brakes after a full brakekleen, then masked and used the silver base coat, then the crystal red top coat for a similar finish to this
Geoff
Looks fabo, did you use a clear coat?
No, the crystal red is a semi clear over silver base. I have some 2 pack top clear and that would be great but might not like the heat.
The metalcast is heat resistant and brake dust doesn't stick so stay crystal red.
You can get purple and some other hideous colour but the red is good for me.
Thankyou for your help.
will try this weekend.
I repainted my a while ago exactly the same. The stencil I had made by a sign shop. I can send you the Brembo artwork and then simply give them the file and tell them that you are wanting a stencil for painting. I did find a stencil kit you can buy, however that was out of the UK. Painted mine using VHT black with silver "Brembo". Went over it all with a high temp clear coat however the clear coat perishes every time I go on the track so I simply wiped it all off. VCHT has been great ever since.
you need the stencils to do the calipers..... i have it if anyone needs....also 2 pack clear is more than strong enough for the application....i dont know why you guys think that single pack paint would be more durable than 2 pack
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
