So is this still on for tonight? 8:30 at futsal or earlier? later?
Yes, its still on and we're planning on meeting at 8:30pm tonight at futsal - for those who are not sure where it is, see the marques in the park thread for the map of where we met opposite Floriade.
I don't know that I've told everyone the results of the photo competition - Mark (Tuk Tuk) came second with this photo
What you don't pick up in that pic is that although he looks further away, with the wide agle lens, he is only about 12" away from the subject, there was a lot of trust required on both sides.
Are we ready for the photo shoot?
Blueprint
R33Driftr
CeJay
unSteddy
micky_tee
Shell
Tourismo
RB20tR32 - you can still come if you change your mind.
Its not too late if anyone wants to join us.
A friendly word of warning to those traveling to the museum tonight, We have the Erindale Collage Formal on tonight, and to give you an indication, We (security) kicked out St Claires Formal last night for various reasons.
Lots of police were around the museum from 6pm till very late in the evening.
Several Cars were impounded or towed away.
Otherwise, If I get a chance I'll come down and say hello
J
You (security)... Thats not nice kickin people out.. haha
yea i just come on to warn you.. im doin a drop off to the formal.. and yea at museum.. drop off if from 6-630... even if you do get there later, im sure there will be a bit goin on when it finishes..
Reece is in town at the moment and says its raining
What would people like to do? Want to go to Civic under ground carpark? bottom level?
Or would people prefer to keep their cars shite and briny?
okay, it appears as if under the bridge is covered with Elton goers. The rain is causing some problems... although I like the wet ground look, so if the rain stopped it could still be good.
Mark is going to meet Tourismo/Reece at Top of Tuggers multi level carpark in about an hour to test some pics - All are welcome to swing by, although if its pouring rain, they will retreat to the next level down.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
