Sorry I took off last night, looked at the time and pick up my meat tray :-)
You missed a good night, we're not long home. I'm too tired to post up pics now, so will try to get some up tomorrow.
Some Very nice pics there,
My car sould be ready by friday (the engine build) but it wont be tuned or have rego. Should be on the road the following friday.
:D
PS, I love your GTR Ladybytes sure it at the skid pad and OMG. Looks great in the pics.
Would love some pics with my car next to it some time.
and tuk tuk, are they all your photos? They are great.
The one with the cars under the bridge is very nice.
Edited by BNR32t
Thank you, I think she's pretty special too :D
You're welcome to come have some shots with us anytime. Always on the lookout for a location to test.
All the ones Tuk Tuk posted are his work.
I checked out that place in Kingston I mentioned, would be alright, nothing too flash though.
In front of the big garage doors at the Old Bus Depot Markets might be better.
The Old Bus Depot should be good for an early morning or dusk shot as well. Might have to check this one out.
If people started turning up earlier, say at say 9pm I wouldn't complain.
Yeah I agree, but I don't think I can make it this Friday, I have to go to Sydney tomorrow and its going to be a big day - Lets see how I feel when I get home.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
