More photos from the last Friday night shoot
Can people let me know what the colour is like in these pics, because although I purchased a colour calibrator for my monitor at home, I can't work out if its my home or work computer which is out of whack. One is deep in colour and sharp, the other is wishy washy.
post-28428-1197839420_thumb.jpg post-28428-1197839571_thumb.jpg post-28428-1197839614_thumb.jpg post-28428-1197839658_thumb.jpg post-28428-1197839763_thumb.jpg
Too much of some colour there, I was going to say too much red but then maybe green when you look at the back ground. Then I gave up.
So who's going out tonight? They are predicting bad weather but I'm thinking not.
I'll be out there for a little while.
Maybe, depends on what I'm up to otherwise.
I ran into someone at the gym this arvo who's keen to head out for a look, some of you may remember him... he has a white R32 GT-R (No it's not radiator boy :thumbsup:)
Those of you who have been around over 2 years may know him
Id be careful, if its a restricted permit and you get stopped by the cops they'll book you for driving un registered because you wont be able to say "Im on my way to get it fixed"... Plus its still double demerits.
Advice - Check your permit before driving.
Hey Ladybytes where were you? You missed a decent turnout :-)
aww I wanted to go but Mark was exhausted from replacing the gearbox in the truck and I felt guilty dragging him out.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
