woden multistory carpark is fairly good one
I was going to suggest that one too, Parl House is out because Australia Day preparation has already started over there.
I'm for a carpark and depending where we meet, might bring my new car out to show yas.
Was going to come but to wet out and more rain on the way :ph34r:
I didn't know you are a girl CJ?
You did drive your car on the skid pad... You should be able to control it by now :)
JK.
PS. Another skid day would be cool.
You did drive your car on the skid pad... You should be able to control it by now :P
JK.
I am a bit of a wuss when it comes to driving in the wet perhaps :D So maybe ill pluck up the courage next time :D .
I am starting to get interested in another skidpan, although I swore I wouldn't after cleaning my car for marques last year lol.
I am a bit of a wuss when it comes to driving in the wet perhaps :P So maybe ill pluck up the courage next time :D .
The more wax you have on your car the easier it will be to clean... says me who won't put my GTR on the pan :D
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
