Hey I might cruise past, I'm down for the weekend from sydney... Hope some of the old crew are out tonight, CJ, Frink, Mick, Pete you know who you are! :P
I haven't seen you guys in ages so if you're free come say hi :/:D
This next friday coming I may come out ... Pending if I have a rear windscreen installed by then ....
Bloody tempered glass only taking one slight knock to smash the thing to peices
  • 1 month later...
I might come out and say hello ... I have now finished putting my new R33 series 2 GTS-T - RE4R01a gearbox in my R32 along with the R33 GTS-T torque converter and flexplate and is all going well ... I think the valvebody may of had a shift kit put through it as the previous owner said it had been reconditioned by autodrive in fyshwick - it seems to punch harder into gears when under full throttle than a standard auto box and the oil that came out of it was clean as a daisy .. nice and red with no contamination :ermm:
Also I have fitted a front strutbrace on my R32 and it is so much nicer to drive ... no bodyroll in the front now it's mad ...
Next on the Agenda is some Z32 300zx 4 piston calipers and I should have some nice brakes ... then will start focusing more on power mods ...
Suspention and brakes were first on my Agenda
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
