We're planning to do a BBQ this Friday.
Start at 7:30pm
Same spot at Gravillea.
Some people have already agreed to bringing some stuff for the BBQ but you may need to bring some meat or bread or drinks to share.
I may post a new thread later on.
What's that got to do with you? Bahaha :P
See some of you tonight.
He and my brother in law, and his missus came over.
I had to operate the BBQ.
Its an unwritten rule, you dont operate another mans BBQ, the turn of meat is ok if permission is given. Usually only ok if the BBQ owner is getting a drink (this usually only happens if the missus is out of yelling range, if this happens too often it is expected that you hand over a man card)
  • Like 2
LOL .. having once lived through that and came out the other end scathed, but not too seriously, I completley understand and believe your post to be a lesson to man kind .. (that's married or seriously involed man-kind)
Well said my friend .. :yes:
Engaged, 3 kids (1 mine and 2 steps sons)
My missus is very '50s,and she knows the BBQ entertaining
The BBQ rules
http://www.poeticexpressions.co.uk/poems/bbqrules.htm
Edited by gtr judd
There is nothing better than a 'very 50's' lady .... you have every reason to skip Grevillea Park an do the BBQ thing .. .. :yes:
There will be many more Friday night's at 'the park' ..
(sorry Shell :closedeyes: )
Edited by THE34T
Ahh the BBQ rules.... now I know why Eiji cooked for us all tonight in the sweltering heat while we ate the rewards of his labour, and he just kept going and going till it was all cooked.
Thanks Eiji! :D
And whoever brought the chocolate brownies. They were good.
Thanks Eiji! :D
No worries Shell. How did you enjoy your night off from cooking? :P
  • Like 1
  • 3 weeks later...
  • 3 weeks later...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
